LED foglight problem
Old May 13, 2009 | 08:13 PM
rclxt's Avatar
4th Gear
I purchased LED foglights and I have a strange problem. Both LED bulbs will work on the driver side but neither will work on the passenger side. Stock fog bulbs will work in both locations. Anyone else heard of this problem?
T
Old May 13, 2009 | 08:34 PM
gold2003tl (90)'s Avatar
2003 TL-p
sound like a wiring harness problem, the male or female connection on the passenger side must be bad or slightly out of contact for the LED.
you might need to get a new wiring harness, but check and see if one of the two contact pins are bent out of place or pushed in too far.
Old May 13, 2009 | 09:59 PM
gfrg88's Avatar
slow tl..
try switching the bulbs around.. kinda hard to explain..
Old May 13, 2009 | 10:03 PM
gfrg88's Avatar
slow tl..
If a button does not light up when pushed in then it may be that the LED has come out of its socket. You can check this by removing the plastic lens cap (simply pull off) and making sure that the LED is correctly seated. If the LED has come out, re-insert it with the legs in the horizontal plane and replace the cap. If it still won't light, remove the cap and take the LED out of the socket, turn it through 180 degrees and re-insert it. Put the lens cap back on and see if it lights now. If not then please contact us for further info.
I had the same problem with my LED license plate bulb. did this, working great now..
Old May 13, 2009 | 10:17 PM
rclxt's Avatar
4th Gear
I dont see where the pins are bent and everything looks fine. Both bulbs are working fine in the driver side socket but neither are working in the pass. socket so its not a bulb problem. I tried cleaning the socket with electrical connection cleaner and even used dialectric grease on the connection. If it is the connector the only way Im going to improve it is to solder in a new pigtail. The only other things I can think of is a weak ground on that side of the harness or maybe a relay but I dont even know if the fogs are relayed. I think Im going to have to break out the multimeter this weekend and take some readings. Thanks for the ideas.
T
Old May 13, 2009 | 10:43 PM
nayaab88's Avatar
It's a sign...go HID!
Old May 14, 2009 | 09:57 PM
Type_S's Avatar
T
This sohould be an easy fix. The same thing happen to me, but with my HID fogs. Incandescent bulbs light up now matter how you connect them, led's and hid's don't. Pull out the pins going into the bulb socket and swap them. That way the positive lead is going to the positive on the led and the same for ground.
Old May 14, 2009 | 11:01 PM
rclxt's Avatar
4th Gear
Ill give the pos / neg swap a try.
Terry
Old May 15, 2009 | 12:00 AM
azn_xxxd's Avatar
.a BUM with SMG...
try to sand it off the connectors if possible.
Old May 15, 2009 | 01:19 AM
thinhthan's Avatar
hey you should post pics of the lights i wanna see how led fogs look like
Old May 15, 2009 | 07:34 AM
fsttyms1's Avatar
Looks bright, does not come close to a decent amount of light output thats usable. HID kit is the only thing i would use.
Old May 15, 2009 | 02:35 PM
rclxt's Avatar
4th Gear
Type S was right on the money. The pos and neg leads were reversed on the pass. side from the drivers. Switched them over and it worked fine. Will try to get pictures up but I am on the road for the next couple of days.
Thanks for the help
T
Old Aug 23, 2009 | 03:56 AM
Legendaryjarl's Avatar
post some pics, btw, how many LED is the light bulb? 18? 68?
jblessing
Aug 8, 2018 09:43 PM
usual.acura
3G MDX (2014-2020)
14
Sep 19, 2015 05:01 PM
Sep 17, 2015 09:01 PM
Greengecko
Sep 16, 2015 08:19 PM
brandnewcolony
Sep 12, 2015 10:39 AM
