Inside door latch
Old Mar 26, 2014 | 09:06 PM
ccgreality's Avatar
Inside door latch
I don't know if what I need is a called a inside door latch but my doors won't open from the outside and I inspected the inside of the door and found that the latches or rods were missing. I'd like to order these parts ASAP does anybody know what they are called. Also my front door won't unlock without the key including when engaging the unlock switch. Is that the actuator??
Old Mar 26, 2014 | 09:45 PM
fsttyms1's Avatar
What do you mean its missing the rods? Are they laying in the door?
Old Mar 26, 2014 | 10:06 PM
Skirmich's Avatar
How the hell are those missing??? If it was indeed missing you will instantly notice it as the door handle should have almost zero load to it, after all if you remove the rods there is only the small return spring in the latch.
As for the unlocking mechanism it could be the actuator its a small solenoid..
Old Mar 27, 2014 | 06:15 PM
ccgreality's Avatar
i believe i checked that when i took off the panels. however i cant recall if they were there or not. i doubt it though. is the name of the part called door rods? i just want to order them and be done with having to open the door from the inside plus i need to put the child lock on my doors before my daughter gets brave and jumps out.
as for the story of how they went missing idk thats how i brought the car now i just want to put it behind me and fix it.
Old Mar 28, 2014 | 11:55 AM
fsttyms1's Avatar
You cant recall if they were there or not? Before ordering parts i would take the panel off again and look. Why waste money and time if that isnt the problem? If one is missing it may have just come unhooked.
mlody
Dec 4, 2019 02:11 PM
soupi
14
Nov 15, 2015 11:15 AM
ROWDY621
Sep 30, 2015 03:20 PM
hashbrown
Sep 29, 2015 12:13 PM
