the diff between air intake
Old May 26, 2011 | 04:07 PM
LILCRIS809's Avatar
im looking to put a cold air intake but im hearing around diff story not to go with cold air to go with short ram i kno one is short and the other is long and cold air get more air
and they told me if i go with any of these intake to go with a good name band for my 2002 tl i like the AEM v2,but i seen a COLD AIR INTAKE call SYDER AUTO COLD AIR INTAKE what the diff these intake has if they not name band ?
i just wanna kno the diff between the name band if they still good cause the price has a big diff
Old May 26, 2011 | 04:21 PM
Karanx7's Avatar
Unregistered Member
If you don't have a Type S, then get a AEM V2.
I'm not able to decipher through the lack of punctuation in your post, so I can't really give any more info.
Old May 26, 2011 | 04:47 PM
LILCRIS809's Avatar
thank but i seen few cold air intake for $50 what the diff on them do you kno im trying to save money but i wont mind buying a v2 but not for no 350
Old May 26, 2011 | 04:51 PM
01tl4tl's Avatar
short ram just gets hot air from engine compartment
CAI goes to front end of car but metal tube absorbs heat,, defeating purpose!
many of us go cheap and remove `intake resonator` that comes out to do a cai-
that opens 2 large holes on bottem of air filter box to gather air from inner fender liner
Use a K&N filter and never have to replace, plus able to process the amount of air now available
here is the diy list- see Resonator Delete https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
Old May 26, 2011 | 05:05 PM
LILCRIS809's Avatar
here is the diy list- see Resonator Delete https://acurazine.com/forums/showthread.php?t=706083
ok so im buy a cold air for $50 and just add a good filter in it then
Old May 26, 2011 | 05:09 PM
Karanx7's Avatar
Unregistered Member
Yea, if you want to cheap out somewhere, do it with a CAI. There's not too much difference between a regular (non V2) brand name CAI and one that you can just make yourself.
$50 CAI can work fine, just make sure the filter is good. Also, hope it's an actual CAI that draws from the resonator compartment. I've seen some that kind of just chill next to the battery.
Old May 26, 2011 | 05:21 PM
LILCRIS809's Avatar
i seen that before but im make sure it go near my tire but im scare since my car is drop but not to low but stil good i herd if i go with a cheap one the pip still going get hot
Old May 26, 2011 | 09:07 PM
01tl4tl's Avatar
listen to me and many others who went the easy route--
remove the resonator box--same as you have to do to install any cai
put a 50 buck K&N filter in there
done
a short ram metal tube inside the engine compartment is going to HEAT the air-
opposite of the desired result
we are as low as you and more~ the bottem of the airbox sits up higher than the rest of the car would survive in a flood! or 3 foot of water
More likely to damage electronics than suck water thru is what I mean
ck it out in the diy section and see why it makes sense to spend $50 in one place and done
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
hashbrown
Sep 29, 2015 12:13 PM
