Wrong Parts
Old Feb 25, 2014 | 08:58 AM
kennedyhuynh's Avatar
Wrong Parts
I bought an ABS sensor driver rear (SU9081) from Autozone. Part does not fit without hammering it in. I also bought a passenger rear abs sensor, this one fits like a glove.
I know a few years ago I ago a CV Boot from autozone and it was the wrong part too. I went to advanced auto parts and they had the same boot. In the end I had to go to NAPA, they had the proper CV Boot.
Question is anyone else have problems with buying parts that don't fit our cars?
These cars are 10+ years old, you'd think all the parts are correct in their databases. Just venting sorry guys.
Old Feb 25, 2014 | 09:07 AM
blame honda.
Honda switches up part numbers all the time.
ive had trouble with my 3G TL.
in 04, brake lines were one way. then in 05, brake lines were changed and the fitting to the ABS module changed.
different parts, same part numbers. same car. different fittings.
you can see how it would get confusing quick. i think i went through 2 brake lines then finally went to a junk yard and found the correct one i needed.
Old Feb 25, 2014 | 10:06 AM
Nicks2001tl's Avatar
There are certain things you can by from the secondary market and some you should go OEM and just suck up the cost. Try rockauto.com. Or one of the sponsored vendors on here.
Old Feb 25, 2014 | 10:12 AM
Also I want to add that things like motor mounts and brakes the after market is better than oem and in some cases less expensive. But things like sensors and your abs system you should go with oem just to be on the safe side, literally.
Old Feb 25, 2014 | 08:56 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Do Not hammer that sensor in !
I did that to mine when I first changed the sensor in the front left, soon after ABS would engage randomly when coming to a stop which is dangerous, the car will keep going forward in some cases until you stomp the pedal the second time.
That was what I experienced, maybe the gap was wrong with the tone ring, just thought I should put it out there. Like mentioned above use oem for this kind of stuff.
Old Feb 26, 2014 | 01:01 AM
Karanx7's Avatar
Unregistered Member
Definitely don't want to hammer it in.
I remember having to get a 10 year old abs sensor out without damaging it. Jeez, took forever.
Old Mar 22, 2014 | 12:45 PM
I bought 3 after market parts and they fit like a glove. Bought oem sensor (left rear)and the thing doesn't fit. Seems like the metal shrunk. I am out of ideas.. Anyone got suggestions. Besides taking it in.
Old Mar 22, 2014 | 12:52 PM
Yikes's Avatar
Couldn't have said it better myself.
Also add to that list ignition system parts. Hondas hate any ignition component that isn't oem for some reason.
Old Mar 22, 2014 | 02:15 PM
Skirmich's Avatar
Never had any problem with Autozone parts.. Not like I changed much anyway.. Brake Pads, Light Bulbs, Rotors, Shocks (When they handled KYB they now use only Duralast Crap and Monroe :/ )..
BUT ABS Sensors? that's definitely a OEM Part I would only buy and Aftermarket sensor if it was made by DENSO only.
Old Mar 22, 2014 | 02:55 PM
Resolved. This one knuckle had so much corrosion it wouldn't fit. Sanded with a drill and some sandpaper. Now sensor fits wonderfully.
NitroViper
Mar 20, 2017 09:50 PM
handsom-hustla
Nov 13, 2015 05:04 PM
Ny1718
Sep 11, 2015 09:21 AM
NetGnome
Sep 7, 2015 08:33 PM
SUPRMN84
Sep 2, 2015 11:50 PM
