99 TL Trans hard shift HELP!
Old Mar 20, 2014 | 11:09 PM
mad-dog's Avatar
this is my first acura and always wanted one, but now thinking it was a mistake after reading all the problems these cars have. someone help me change my mind. when starting from a stop it shift real hard from 1st to 2nd, 2nd to 3rd sometimes hangs, and 3rd to 4th shifts pretty normal. on the drive to work (100 miles one way) every now and then I fell a real slight pulse like it wants to down shift but doesn't. have no CEL's for the trans just the EGR which I have already cleaned the ports under the intake, but now I think its actually the EGR valve itself, just need to get it replaced. already cleaned the solenoid valve screens, what else is left any suggestions would be great!
Old Mar 21, 2014 | 03:10 AM
Skirmich's Avatar
It only hard shift? are you sure it doesn't over-rev?
Also "All the problems these cars have"? You got a 99 only problem you should be hearing off is Heated Seat element and some minor issues with A/C nothing extraordinary since you have a 4 speed which is EONS more reliable than our 5 Speed.
Hard shifts can mean 2-3 things usually we pin point the Trans as the troublemaker but sometimes stuff as simple as Motor Mounts/Trans Mounts can be to blame too.. Even old ATF can cause hard shifts..
Old Mar 21, 2014 | 08:34 AM
Nicks2001tl's Avatar
Check the side engine mount first, you can visually inspect it. If it is torn the front engine mount might be broken also.
Old Mar 21, 2014 | 10:50 AM
03blackbeast's Avatar
Yeah, I agree with what they said. I just had the AV6 installed on my 03 and I'm running on the stock mounts at 270K miles so I get hard shifts especially after a cold startup. I'm just too lazy to replace the mounts. Doesn't really hurt anything though.
Old Mar 21, 2014 | 05:00 PM
3.2TLc's Avatar
If you're planning on keeping the TL, ya should've had the mounts replaced with the "AV6" installation.
It's money well spent to maintain the overall quality expected from an Acura. Just git 'r done !!!
Old Mar 22, 2014 | 08:55 PM
mad-dog's Avatar
sorry it took a couple days to respond to every ones useful tips, thanks for all the knowledge, ill definitely look into the mounts. thinking about it that sounds like the logical fix. ill keep everyone posted
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
Sunnyj209
ILX
Sep 30, 2015 09:31 AM
Brandle34
Sep 23, 2015 07:20 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
