WOOHOO! I just "rededed out" my tails
My "P" SpAnKs YouR "S"
Originally Posted by Da_iLLeZt_TL973
they look nice
i like em alot they would look hotter if the car was red but good shit wat did u use??
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Originally Posted by 55M2G7L
you used red tints? where can i get that?
luvs redheads!
![Arrow](https://acurazine.com/forums/images/icons/icon2.gif)
u could of taken them apart and tinted the reflective strip between the brake lights and blinker black and the changed the amber to red with transparent paint...............we decided to keep the amber cause it already looked badass!
-swift/ben
-swift/ben
did you put the 3m tint on the outside of the tailights? If so how would it stand up in the rain? I was thinking of doing that to my tails but I'm not sure if the tint would hold up in the rain or when I wash the car.
it does look really nice. but i have to agree with Dai, how does it light up when you put your car into reverse?
and i got the same question as everyone else, how did you tint it? there's a place i know to get colored tints in my neighborhood, but i want to know how to do this first before i grab a sheet.
Liquid Ice
Originally Posted by Dai
Looks good, although I think you should have masked off your reverse lights as now they're red.....
This is what mine ended up looking like:
![](http://www.nbvb.com/~chungr/images/carpics/2004_10_03/IMG_0610.jpg)
The red isn't a 100% perfect match but most of the time you can't tell unless you're standing real close to it. It looks kind of odd in this picture because the light is hitting it differently.
Originally Posted by LiQiCE
Yeah I was thinking the same exact thing. I redded out my tails too but I used a razor and cut out the reverse light area.
Yeah in this picture you can tell...The right side tail light looks like it fits in just fine, but like he said, with the light hitting the left tail it does look unnatural
ok ill give it a try, can u post a DIY on this?
![](http://img167.exs.cx/img167/429/people0151zc.th.jpg)
Click here.
It's way easy , just take your time. Im not a pro but this worked for me.
Clean your taillight first....
1. spray soapy water onto amber section. then apply tint (without removing backing) just to measure it.
2. Cut off excess material with blade or exacto knife. leave 1/4 of an inch beyond taillight. If you want you can cut reverse light section out. ( I didnt)
3. while tint is on taillight and you have done all the cutting use a blowdryer (what I used) or a heat gun to curve the tint and form it to your light. use a hand towel to smooth it out while heating tint. it will mold to the shape of your light. that curve is hard to apply tint to, unless you heat it up.
4. take tint off. apply alot of soapy water, take backing off tint, apply tint to taillight. use the bottom of amber section to guide the tint. Let it sit on there for 2-3 mins. smoothout with towel. (To get bubbles out)
5. Take your blowdryer and heat tint while on taillight and try to smooth out the curvy part of tail. Thats it.
DISCLAIMER: If it doesnt work , Dont blame me.
This may help also: http://members.cox.net/rsxmotorsports/
Liqice is the one who inspired me to redout my tails. I think he used vinyl film (tint). not spray. He did it on top of 02' tails which makes it easier to cut out reverse light, but I have 00' lights so the reverse light is surrounded by amber. (I went the easier route)
Liquid Ice
liqice, that looks like spray, cause tint is not that dull
Here's another picture where the red looks more natural...
![](http://www.nbvb.com/~chungr/images/carpics/2004_07_17/IMG_2050.jpg)
Like I said, under normal circumstances you can never tell that the red isn't a perfect match unless you go right up to the car and inspect it.
TL_Fo_Life - Yours looks good, I wanted to go full red too, but I don't think I can pass safety inspection with the reverse lights redded out. If they check for that in your state you will most likely fail safety inspection too unless you know somebody
I originally was going to go with a blacked out turn signal, but it looked weird since it wasn't very dark even with 20% 3m vinyl "tint".
Off topic, not to hijack the thread, but what springs did you use to lower your TL? I like the height, not too low where you look like you're gonna bottomout on a bump and not as high as the stock. After you respond, y'all can resume the tinted taillights talk.
PS. I vote no on the red tint. I'm gonna put in clear LED lights that blink yellow so the blinker will look all white when not on.
Its vinyl film. Not exactly the same as tint, but its meant to handle the weather and stuff outside. It is applied the same way as tint though, you clean the outside of the light as best as possible with alcohol or whatever and then apply the film and cut it the way you want with a razor blade.
Liquid Ice
I have Tein SS coilovers. So the ride is height adjustable. I have mine lowered roughly 1.75" all around..
Liquid Ice
Thanks. Are the whellwell gaps over the tires the same front and back or is the front a little higher than the back?
![](http://www.nbvb.com/~chungr/images/carpics/2004_12_05/IMG_1565.jpg)
Like I said, its height adjustable, so you can change the height to whatever you want.
Mine are fairly even, but because the wheel wells themselves are not exactly in the same.
Sorry to load up this thread with so many pictures.
Liquid Ice
Originally Posted by MikePA
Where'd you get the Tein SS Coilovers? Did you install them yourself? Car looks great!
I'd rather be driving:
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
TL_Fo_Life,
Now you gotta do something about your grille! :ghey:
>>2000 TL-P Navi<<
-Pimp Naples Gold
-CAI, DeBadged, 20%/35% 3M Tint, Gay Custom Grille, "Red out" Tails, Air freshener....
-Future mods: More than I can afford.
-Pimp Naples Gold
Actually, even when I had the Acura dealer install them it was down for about 2 days but I got a loaner.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Liquid Ice
Originally Posted by fsttyms1
2 days????
i coulda done it in like 2-3 hrs
I'm also guessing my car didn't just go up on the lift and get installed right away though ...
wusty23jd
09-24-2015 11:41 AM
ivegotthenav
09-11-2015 07:51 PM
