will removing resonator screw with flow
Old Mar 23, 2003 | 12:49 AM
bigman's Avatar
'Big Daddy Diggler'
will it cause me to loose power or gain a couple ponies. I dont want to loose any low end torque. And i am talking about the large resonator.
Old Mar 23, 2003 | 12:16 PM
2001TL4KCdude's Avatar
Oracle Apps/Database Dude
I took mine off yesterday and I have not noticed a decreased in low end torque. If anything I noticed a slightly free flow in exhaust (maybe my lead foot is biased). I have a short air ram and I do notice at higher rpm it sounds better. I do have stock mufflers. I took out the 1/2 muffler size resonator. I am thinking of removing the small (2 liter coke size) one as well. There is no rumbling at idle. The car sits quiet.
Old Mar 23, 2003 | 06:02 PM
Darkshear's Avatar
l33t
yanked mine out a while ago. sounds better, no problems.
Old Mar 23, 2003 | 08:26 PM
bigman's Avatar
'Big Daddy Diggler'
will i gain anything power wise
Old Mar 23, 2003 | 08:42 PM
Darkshear's Avatar
l33t
If you remove the resonator you will have to reroute the air flow unless you want it sucking the air from behind the splash guard, which is no big deal. You will get some gain, as the resonator restricts air flow, and it brings it in from the engine bay through a tiny-ass hole. But you should get a K&N filter to allow the higher airflow as after you remove it, it will be coming right through the 3" hole at the bottom of the airbox. After the K&N is when you will notice the difference.
-me
Old Mar 23, 2003 | 10:59 PM
fsttyms1's Avatar
are you talking the exhaust resonator or the factory intake resonator? if its the exhaust i would say remove both if you are runninf factory exhaust. im not really sure why the have them on there there is hardly a sound difference with them off (a lil deaper sound) now if you have the comptech exhaust i would recomend just taking off the small (2 litre coke bottle size) because the resonance is REALLY BAD! i just ordered the silent tip inserts to see if they help, but i have noticed the mid to redline power is alot better with the comptech no resonator combo.
Old Mar 24, 2003 | 07:58 AM
Darkshear
There are 3 resonators. 1 intake resonator that sits under the airfilter box, 1 exhaust resonator that is a 2 liter coke bottle size I mentioned and 1 resonator that looks like a 1/2 size muffler before the Y pipe. The question is regarding the larger of the 2 'exhaust' resonator.
Old Mar 24, 2003 | 08:45 AM
fsttyms1's Avatar
like i said before removal of the larger (looks like a small muffler) wont hurt any thing, it will free up your exhaust flow (which is a good thing. if you are running a factory exhaust you will be fine, if you are running hks or comptech it will be loud
Old Mar 25, 2003 | 09:42 AM
Red Hot TL's Avatar
so... anybody wants to record Comptech exhaust without the exhaust resonators?!?!
Old Mar 25, 2003 | 02:13 PM
fsttyms1's Avatar
ill try to this weekend. the problem isnt with the sound outside the car, that is totally awsome sounding, its the sound inside the car that is almost unbarable. the resonance is enough to drive a person nuts. it will litteraly shak your soda cans in the holder at 2000 to 2500 rpm
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
eastsideride
Oct 15, 2015 04:26 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Desert Ridge
Sep 27, 2015 02:37 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
