Will this key work for our TL? PIX
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1873139924
This key is made for the new 2003 Honda Accord. Do you guys think it will work for my 2002 TL-S? I'm thinking it should, no reason for it not to work, right?
Your best bet is to contact your dealer, talk to someone who knows their stuff... and ask them about the security chip. I do not know off hand if Honda and Acura use the same security chip in their keys.... so you will need to find that out.....
Originally posted by baggsTLS
John, check w/ Tim at hondacura world. He should know.
Actually, Honda began using a new type of "key" in the 2003 Accords as you can see in this pic below. You see how it's cut on both sides yet it leaves a slim edge at the center. More differences you can see like the lack of grooves.
IMO, the chip is probably carriedover technology so it "may" have worked. But unless you modifying the old key with this, you guys are out of luck
Hell, maybe the lock cylinders can be changed
update!!!
Great news everyone!!!! This key will work for our TL's.
The new 2003 Honda Accord key uses the same remote FCC and the same security chip inside the key.
The new Accord part # is:
Honda Part # : 72147-S0K-A11
FCC : E4EG8D-444H-A
Look at the back of our TL remotes, it also says:
FCC: E4EG8D-444H-A
And they also come with Memory 1 and Memory 2.
Any honda or acura dealers can cut the key for you. Just make sure you bring along a spare. They need to throw both keys into a machine and it will copy the security chip code over. And as for programming the remote, anyone can do it. You can actually do a search in the Forums. Hope the new 2004 TL's comes already in one piece.
FCC : E4EG8D-444H-A
FCC: E4EG8D-444H-A
Originally posted by Daimler560
Wonder if Acura will have a car with a similar Key...it might look better.
JohnC1010
Was it a Honda or Acura dealer that made the confirmation?
Remotes might be the same, but the key blank does not have the center groove.
I'm not a key expert, but I have never seen a machine cut a center groove before.
Originally posted by justint
I like the new key since it likes a BMW key and one less to carry. Hope that the new key is as good as the BMW key.
It's so awesome, this key has a transponder built-in and has rolling code as well as built in remote of course.
Thing is, key is CUT differently!!! I really pray that ACURA becomes more than BMW and shuns them down b/c, Lexus is still no BMW or Mercedes in terms of function but only in terms of prestige.
Acura isn't prestigious as of yet, well OKAY, the MDX and Type-S models (TL-S, CL-S, RSX-S) are prestigious.
The Japanese realy NEED to hurry up and conquer the Germans in the luxury car game. it'd be nice to see AWD TL's or CL-s b/c, the age old debate of FWD vs. RWD will then vanish.
Re: update!!!
FCC : E4EG8D-444H-A
FCC: E4EG8D-444H-A
FCC : E4EG8D-444H-A
FCC: E4EG8D-444H-A
Then you have the problem with key lenght, width and thickness, is anyone curtain that it fits.
And last is the transponder...honda probably kept it the same, no need to fix somthing that aint broke.
The thing i can tell you is that, the new key Lock/Unlock/Trunk/Panic buttons will work. Not sure if it will open doors or turn on engine or not
That sucks. It will still mean we have to carry two items
......a remote that looks like a key, and the actual car key itself.
That sucks. It will still mean we have to carry two items......a remote that looks like a key, and the actual car key itself.
Originally posted by AndySara
[B]
[B]
And "just if" the transponder in the key "are different" you could get a transponder bypass...about $20-$40. That's what they use for remote starts, when you don't have your key in the car and your able to turn on the car.
[B]
there's maybe a way to customize our TL keys onto the new accord keys.
[B]
what is it exactly that u guys like about this key? That it has built in immobilizer and rolls code everytime u unlock and lock like Mercedes? I think it has good features but it is probably pretty fattt.... I like those Passat/BMW Keys that lock open like a swiss army knife when u press a button.
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
ahsm
Sep 9, 2015 08:35 AM
