will 00 and up engine fit
Old Aug 10, 2009 | 02:09 AM
thinhthan's Avatar
will the 00 and up engine fit in a 99 tl with a 4 speed tranny? or will i have to change out the 4 speed to the 5 speed tranny for it to work?
Old Aug 10, 2009 | 03:06 AM
01tl4tl's Avatar
I know there would be great effort in installing a 5 speed- the shifter console isnt built for it and the computer is 4 speed
You could drop an entire assembly in like the guys with the 6 speed & CLS motor
with appropriate wiring harness
whats up- you get bad news on the trans?
Old Aug 10, 2009 | 03:08 AM
01tl4tl's Avatar
motor swap experts: Can he drop in an 00 engine and mate it to a 99 trans? thanks
Old Aug 10, 2009 | 04:48 AM
Rajca's Avatar
wham bam thank you ma'am
dont think its gonna work. is it a type s engine or r u using a tl-p if a 00+ tl-p engine and a 4spd tranny with a tl-p ecu. it might work. but not with a tl-s engine and a 4spd tranny
Old Aug 10, 2009 | 04:51 AM
Aman's Avatar
Your Friendly Canadian
I thought the TL-P engine was the same from 99 to 03. Different transmission, ECU etc, but isn't it the same engine?
Old Aug 10, 2009 | 05:53 AM
Rajca's Avatar
Diff intake manifold, think that's all. So I don't know if it will have diff sensors bc of that
Old Aug 10, 2009 | 03:37 PM
thinhthan's Avatar
cause i was gonna get me a tl-p from a 00 and put it into my blue 99 for now. but iono if the 00 engine will work with my 99 tranny using the stock 99 ecu
Old Aug 10, 2009 | 04:05 PM
FirePR2002's Avatar
bringin lead
i believe the answer here is NO.
Old Aug 11, 2009 | 02:46 AM
thinhthan's Avatar
i guess ill just have to keep looking for a 99 engine than cause i got no luck finding a cl
Old Aug 11, 2009 | 07:18 AM
fsttyms1's Avatar
the motor will bolt up just fine. But the problem lies in the ECU. The 99 has slightly different cam timing for vtec that i dont think will work well with the 00-03 motor very well??
Old Aug 12, 2009 | 12:59 AM
thinhthan's Avatar
will i be able to just plug in a 00 ecu to or is the pins different?
Old Aug 12, 2009 | 07:25 AM
fsttyms1's Avatar
wiring is different.
Old Aug 12, 2009 | 11:13 AM
phee's Avatar
I got the Shifts
it will work. you wont have any codes either. just dont go putting a 5 speed tranny in.
but the tl-p engine will fit and function in a 99. only issue you will have is getting your temp guage to work. you will have to tap the thermostat housing to place your temp sensor. (i just used a t in the hoses)
Old Aug 12, 2009 | 02:16 PM
thinhthan's Avatar
ok so i could put a 00 and up tlp engine into my 99 using the 4 speed trany and the 99 ecu and it will work correctly right? the only issue is the temp gauge?
oo7spy
Jun 19, 2023 12:48 AM
Feb 25, 2020 09:57 AM
drone619
Jan 26, 2016 07:09 PM
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
