Whining/Squealing Sound
Old Feb 24, 2013 | 05:41 PM
xakura21's Avatar
I just noticed a whining/squealing sound coming from my engine only when I accelerate. What are some possible ideas that could be causing this? The timing belt was just changed last year, could I have slipped off a little?
Old Feb 24, 2013 | 09:40 PM
Severin's Avatar
Does it happen if the car is in park or neutral and you hit the gas?
Old Feb 24, 2013 | 10:29 PM
Carson-TL's Avatar
Same thing happens to me, but its been happening since I got the car. I looked around and a lot of people hear this sound too so I kinda just figured its normal.
Old Feb 24, 2013 | 11:46 PM
Carson-TL's Avatar
Oh and it only occurs when I'm in 3rd gear, does the whine happen in multiple gears?
Old Feb 25, 2013 | 01:41 AM
Skirmich's Avatar
A Video would Help ALOT otherwise we will just guess here.
Those sounds most of the time come from A) Belts B) PS Pump C) Belt Tensioner
Old Feb 25, 2013 | 07:52 AM
3.2TLc's Avatar
Yeah, ^^^^ as Skirmich said.
With the car parked and motor running, see if the noise is originating from the drive belts, accessory pulleys or idler tensioner.
More than likely a worn dry bearing or a misaligned belt.
Old Feb 25, 2013 | 08:09 AM
xakura21's Avatar
I don't hear the sound while in park or neutral, just in drive. Like Carson said, I only hear it around 3rd gear. I had problems w/ 3rd gear when I first got the car & I didn't know about the trans in these cars & got it fixed, but it still feels different than the other gears. It wasn't fixed by Acura, but by Amcco, who only deals with transmissions & I have a lifetime warranty on it.
Old Feb 25, 2013 | 05:36 PM
3.2TLc's Avatar
If it's not the belts or pulleys, than ya may want to pay AAMCO a visit !!!!
Old Feb 26, 2013 | 01:36 AM
Carson-TL's Avatar
So I took some video while driving to see if I can get audio of the "whining" sound, you have to listen really close it doesn't start until 25 seconds in.
[.video=youtube;ZC9AYPZKYgg]http://www.youtube.com/watch?v=ZC9AYPZKYgg[/video.]
Old Feb 26, 2013 | 01:38 AM
Carson-TL's Avatar
dammit I tried to embed it but that didn't work obviously, I don't know what I'm doing. so heres the link instead:
Old Feb 26, 2013 | 02:03 AM
Skirmich's Avatar
Damn it.. I just hear Road Noise all Over!
You cant replicate the sound standing over idle? or It does the sound moving only and at 3rd gear?
Old Feb 26, 2013 | 10:38 AM
Carson-TL's Avatar
if you turn it up and listen really close you might be able to hear it. from 25 seconds to the end is when it became audible. its the high pitch "weeeeeeeeee"sound you hear. yeah no, its not there when I'm idling (trust me I've had my head under my hood enough that I would have caught it a while ago...) only when I'm moving.
Old Feb 26, 2013 | 03:35 PM
xakura21's Avatar
I heard it & mine makes the same noise. I guess the only way to bypass it is to put in a 6 speed. &
Old Feb 26, 2013 | 10:11 PM
Carson-TL's Avatar
Man, I'm so frustrated! I wish I had the money and the skill to put in the 6 speed!!!!!!
Old Feb 27, 2013 | 08:04 AM
xakura21's Avatar
^^^^^^x2
Old Feb 27, 2013 | 08:32 AM
3.2TLc's Avatar
Cool Whinning and whinneeing....yipiekiyaoh !
Hey Carson-TL and Xakura21, have either of ya attempted to listen to the belt driven accessories, the associated pulleys and idler tensioner ..... while increasing the motor's rpms in park ? The noise may not rear it's whining head until it reaches a certain momentum of spinning the drive pulleys. If that doesn't help, turn up some good ol head bangin' R&R.
Old Feb 27, 2013 | 09:30 AM
xakura21's Avatar
Haha, I usually do have the radio blasting, so I can't hear anything. Lately everyone I pass by starts looking at me & I'm like, what? My car can't be a head turner yet?!? It's still stock! That's when I turned off the radio, rolled down my window & listened to the heart of the car, yes the engine. I think all I have to do is a tranny flush & oil change & I'm good to go... I hope. (Yeah, I'm overdue for an oil change)
Old Mar 2, 2013 | 03:57 AM
02 TL's Avatar
Careful with the tranny flush. If the car hasn't had it done every 25k to 30k miles, new fluid may damage your tranny. If the fluid is old, you're better off flushing like a quart and adding a quart. I had mine rebuilt, this is what the tranny specialist and all mechanics I've ever dealt with have told me.
Old Mar 2, 2013 | 04:00 AM
02 TL's Avatar
About funny noises, I get mine from the power steering pump. I also get like a crackling sound every so often. I think I have a pulley or something that's bad. I should record a video of that and get some feedback from Aziners like you did.
Old Mar 2, 2013 | 04:02 AM
02 TL's Avatar
Sometimes a bad ground can cause your speakers to make a sound like you mentioned too. Different gears, different volume. In this case you would hear it when the gears shift
Old Mar 2, 2013 | 08:07 PM
Carson-TL's Avatar
Actually now that I'm really paying attention to the sound it most audible in first and slowly fades until the sound is gone in 4th gear....oh well, I'm not too concerned, it just sounds like regular car noise.
Old Mar 2, 2013 | 11:14 PM
Chevelle66's Avatar
I recently noticed a "whine" as well when on the freeway. I haven't messed around with speed or gears yet, but it's only when on the accelerator, if I coast it goes away. If it were a belt or what not I'd suspect it would make the sound regardless of accelerator and be dependent on RPM speed. I had a similar sound on my 1977 Datsun 810, exact same sound but louder and only when I pressed the gassed and released did it happen. I'm assuming it may have to due with the intake? What all changes on the car when the accelerator is pressed? (besides rpm haha) That should narrow it down.
Old Mar 3, 2013 | 04:02 AM
3.2TLc's Avatar
Talking Listening to the car's heart beating......
Haha, I usually do have the radio blasting, so I can't hear anything. That's when I turned off the radio, rolled down my window & listened to the heart of the car, yes the engine.
Yeah, sometimes it's a good thing to actually listen to your car's sounds as they can possibly be telling ya of impending mechanical problems.
Old Mar 4, 2013 | 04:53 PM
TLer trash's Avatar
If it's so loud that people on the sidewalk are turning to see what the noise is, I'd be looking at the drive belts, or something driven by them. (ac, ps, alt.) Or the belt tensioner.
Old Mar 4, 2013 | 05:09 PM
AcraAdi93's Avatar
Damn our TLs with these noises wth...
Old Mar 5, 2013 | 07:50 AM
3.2TLc's Avatar
Lightbulb To bypass annoying noise......
Yeah, then ya would really have a screamin' mean machine !!!!!
mlody
Dec 4, 2019 02:11 PM
DerrickW
Nov 15, 2015 05:52 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
