what is this symptom suppose to be
Well, I am having trouble starting my car in the morning after a cold night. Sometimes I leave the car outside and when I do, I have problems starting my car up in the morning. It will choke but it wont crank thru and after like 5-10 mintues of trying THEN it goes thru and when it does, its really weak. I have rought starts like that the first time starting the car. After that and after driving around for a little bit, it will start weak but I can get it on the first try. What is my symptom and what needs to be changed? THanks
1. Honda is notorious for being sensitive to summer-winter gas change. If you just started having this problem, try to fill your gas tank with fresh gas first.
2. If the problem is not gone, you might need to check your fuel system, specifically – fuel injectors. Modern fuel injecting systems use fuel rail to retain fuel pressure. Then injectors open and close repeatedly to spray fuel into intake manifold. It seems that one or two injectors do not hold pressure and leak. When you start the car and there is no pressure in the fuel rail, you have to pump it up first. Try to turn ignition key on and wait for 20-30 seconds prior to starting the car. During that time fuel pump will pup up gas compensating for leak overnight. If it will work, then your injectors are not good (one or few).
Originally Posted by mlionel
I can think of couple problems here:
Originally Posted by Nyses
or maybe the battery? or the alternator
Altanator
starter
fuel injector
Thanks. I thought it was the gas ta first too but I filled it already. This problem has been going on for ahout a week and half to 2 weeks. The second solution aI asked my friend and he say that could be the problem and he never thought of it. SO the question is how much to replace the fuel injectors, is it DIY or I have to take it to the shop. Lastly, when you say turn the ignition on is it first slick or second click, prior ro starting the car. THANKS!
I need 2 more gears
maybe something simple like loose battery terminal(s). if you bought your battery 3 months ago there's is a decent chance the terminals have loosened up a bit. I had a similiar problem with my wifes car and it turned out to be the last thing I checked, the battery terminals. BTW does your car try to turnover and just making clicking sounds or do you feel like starter is engaging and try to start the car but for some reason it isn't turning over fully?
Received 1,080 Likes
Put a volt meter on your car and have someone start it.
Get measurements:
1 - Cold, ignition off
2 - While cranking
3 - When started
I agree, it's most likely the battery.
Get measurements:
2 - While cranking
3 - When started
Last night I tried to start my car. I put it in second click for about 30 seconds and it did not work. I tried about 10 times after thatm all giving about 30 seconds in second click and it did the same. It will choke and it sound like its almost starting but it wouldnt go thru. Then I let the car rest for about 1-2 minute and just cranked it and it went thru. I let the car warm up and went for a drive. Everything was smooth.
Then today, I didnt drive me car all day. I tried to start the carthe first time, jsut tryng to crank it thru the first time but it didnt start. Then I left the key on second crank for bout 30 seconds and then it crank thru.
After all that, does it start to look more like its the feul injectors? If so How much to change them and is it DIY. Thanks
Dragging knees in
Okay, next time, don't try to start it right away. Turn it to"ON", the position before the one you would turn the key to when you're starting the car. Just leave it there for a few seconds, then try to start it. If it starts up on the first try, then there might be something wrong with the fuel system. Leaving the key in the "ON" position primes the fuel pump. Just a hunch.
Originally Posted by 03CoupeV6
The green key in the instrument panel isn't flashing while this is going on is it?
Have your spark plugs replaced first then move on to the fuel injectors, but dont replace them. Just have them cleaned.
Do you have problems starting the car when it is hot or only when it is cold?
It's not the alternator. If it was your battery would never charge and you would not be able to start it at all.
I am having this same problem. No one ever comes back and says how they fixed it. Please Help. Now my car won's start at all. I sprayed carb cleaner in the intake pipe and it started right up, but now it still does the same thing. It will crank over forever and not start. I replaced the fuel regulator, and nothing. I think it's a fuel pump, but I don't know. HELP PLEASE.
Jamus22
06-11-2023 10:08 AM
SidhuSaaB
05-30-2020 12:40 AM
dainmezron
10-16-2015 06:56 PM
us285126
10-02-2015 02:03 PM
