What problem could this be? Vibrating issue
Old Mar 7, 2016 | 09:02 AM
KamikazeTL's Avatar
TL ftw!
Hey guys I just ran into more problems with my TL. It's been happening for 2 days and I'm scared to drive it now.
On my way to work I experienced it vibrating when I was at a stop sign. Then when I went to accelerate it would take awhile to accelerate then it would have a major jerk shift then accelerate. I will be taking it to a mechanic after work.
I'm assuming it could be the transmission mounts? I replaced the motor mounts about 3 years ago
Old Mar 7, 2016 | 06:16 PM
MarcDavidoff's Avatar
Is there an engine light on? Sounds like it could be as simple as a bad coil
Old Mar 8, 2016 | 09:47 AM
CP13's Avatar
When you say "accelerate" do you mean that your RPM is revving high and you are not moving any faster then suddenly it jerks and goes forward?
Old Mar 8, 2016 | 04:05 PM
Karanx7's Avatar
Unregistered Member
If that's the case, you should do some work asap. Might be possible to extend the tranny life a bit by servicing it.
I started having tranny issues, and they went away for ~2 years with a 3x3 and a filter change.
Old Jul 14, 2016 | 11:26 AM
DaJaySterrr's Avatar
7th Gear
Similar thing happened to my minivan it just was way overdue for an oil change there wasn't enough oil for VTEC to kick in
neuronbob
3G RLX Problems & Fixes
Oct 20, 2019 02:55 AM
Evilocity
Apr 22, 2016 09:33 AM
tiger2471
4G TL Problems & Fixes
Mar 1, 2016 08:39 PM
Dilawer
Feb 20, 2016 06:45 PM
gemz_acura
Jan 18, 2016 04:41 PM
