What to do for better handling?
Old Oct 27, 2003 | 01:50 PM
thsiao's Avatar
Happy with my STi!
I want my TL Type-S to have a better handling at corners and in general... what should I do? What brand? How much?
Thanks.
Old Oct 27, 2003 | 03:00 PM
sc354's Avatar
go with either Comptech Springs, or H&R Sport Springs. if you're still dissatisfied with the handling capability after that, put some CT sways on, then let us know what you think.
Old Oct 27, 2003 | 08:38 PM
fsttyms1's Avatar
18's with a really good tire! then some lowering springs
Old Oct 27, 2003 | 08:45 PM
Twenty03 Type-S's Avatar
Better handling?
Tires...
Shocks...
Sway bars...
then springs
Old Oct 27, 2003 | 10:48 PM
NsX Pilot's Avatar
Originally posted by Twenty03 Type-S
Better handling?
Tires...
Shocks...
Sway bars...
then springs
ditto
Old Oct 27, 2003 | 11:47 PM
Allout's Avatar
Blown is Best
1) Springs and Struts together
2) Tires
3) Sways.
Old Oct 28, 2003 | 01:31 PM
RUF87's Avatar
Lead Footed
2) Tires
3) Sways.
I did CT Spring and Sways with Toyo T1-S tires.
Lovin' it.
BTW - your first name wouldn't happen to be Tony would it?
Ruf
Old Oct 28, 2003 | 03:21 PM
hemants's Avatar
1. Tires first
2. then sways
3. then springs/shocks
The first two will get you 90% of the way there.
P.S. You may get differing opinions here but I have driven cars with tires only, sways only, and springs only and based my conclusion on that.
Old Oct 28, 2003 | 08:56 PM
bronx02tl's Avatar
2) Tires
3) Sways.
Now this is obviously the most sensical way to go...why would you ever change just the shocks without the springs or just the springs without the shocks.
Old Oct 28, 2003 | 09:29 PM
Allout's Avatar
Blown is Best
Yeah, but I see it all of the time here on the board. Springs without struts is a common question and occurence.
Old Oct 28, 2003 | 11:39 PM
thsiao's Avatar
Happy with my STi!
My first name IS NOT Tony by the way... thanks for the comments... I thought shocks and coil overs did more good than the sways.
Old Oct 29, 2003 | 09:09 AM
I would agree that if you were going to a different spring (i.e. something to lower your car), you *should* replace the shocks because of the reduced dampening length of the shocks.
Remember shocks (struts) dampen the vertical motion induced by driving your car along a rough surface. Shocks absorb any larger-than-average bumps in the road so that the "shock" of the road isn't transmitted to the car chassis; they also keep the suspension at as full a travel as possible for the given road conditions. Shocks keep your wheels planted on the road.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
chasingthecool
Mar 9, 2017 05:16 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
