water pump and belts
Old Aug 13, 2007 | 03:20 AM
nine's Avatar
7th Gear
hey guys new member
i am looking for diy for water pump and belts. Anybody done it,maybe some pictures would be nice.thanks
Old Aug 13, 2007 | 09:14 AM
fsttyms1's Avatar
Welcome to the forum. This is the closest thing to a DIY for the timing belt. Once thats off you will have access to the H2O pump.
https://acurazine.com/forums/showthr...ht=timing+belt
Old Aug 13, 2007 | 10:49 AM
boop2002's Avatar
take it to the dealer, or somone who knows what they are doing, this is no diy depends on your skills. have the comfort that if someone else does it and your engine goes boom they are responsilbe not you. just my two cents. time is money save the headache and just shell out the cash
Old Aug 13, 2007 | 11:10 AM
02TLSfan's Avatar
Prick of the month
^^Private mechanic not the dealer, any dealership will gladly charge you about twice what a reputable mechanic will. Try to find a Honda/Acura specialist, there has to be one near you, these are some of the most driven cars out there. I checked a private mechanic here and they said $425 if I brought them the parts, about $600 if they supplied the parts; dealership wanted well over $1000 either way.
Don't forget spark plugs, I just bought some NGK Iridium IX plugs for $6.99 each, the dealer wants $26 each for platinum plugs and $150 to install.
If you're comfortable doing it yourself or have a friend who's knowledgable skip the dealership at all costs.
Old Aug 13, 2007 | 11:16 AM
Johndoyle's Avatar
Totally depends on your skill level
I have done several timing belts (including water pumps and accessory belts) with good results, but have done lots of fairly major DIY project (cylinder heads off, engines out, clutches, too many water pumps and belts to list) and found it straightforward.
I agree that the consequences of screwing it up are bad, so don't proceed if you haven't done projects at this level. If you have done major work and are patient and careful, however, this job is not terrible. When in doubt, stop and research. Plan on tying up the car for a while and making some tool runs. You will need to buy a tool to hold the crankshaft pulley so you can remove the big nut on the end. You can sometimes loosen it with an impact wrench, but you can't count on that. Other than that, just regular mechanic's tools. Just expect to spend twice as much time as an experienced mechanic would spend and triple check your work.
Good luck!
Old Aug 13, 2007 | 06:58 PM
Southern's Avatar
The post I did for the water pump and belts provides some pics and tips and I strongly recommend the factory service manual if you intend to tackle this yourself.
I do not recommend trying this yourself solo if you havn't done a timing belt replacement before. This was my second timing belt replacement, first one was on my 88 Honda Accord.
I found out trying to document the procedure that it is near impossible to take good pics since there is too much engine stuff in the way. The factory service manual has some great illustrations but they can be misleading since they do not show or mention the obstructions.
Old Aug 13, 2007 | 09:48 PM
nine's Avatar
7th Gear
thanks guys i think i will take it to a private mechanic.acura of las vegas asking 1300+tax
Old Aug 13, 2007 | 09:50 PM
nine's Avatar
7th Gear
i only got 60000 miles on it and second tranny
Old Aug 14, 2007 | 02:15 PM
TLover8888's Avatar
can anyone recommend an online site to get a new timing belt and water pump??
Old Aug 14, 2007 | 02:28 PM
fsttyms1's Avatar
Yea, the same site we recommend for all other OEM parts
http://www.acuraautomotiveparts.org/...catdisplay.jsp
Old Aug 14, 2007 | 02:34 PM
TLover8888's Avatar
thanks!
another question: when ordering the timing belt, i'm assuming i get the lower AND upper timing belts?
Old Aug 14, 2007 | 02:49 PM
fsttyms1's Avatar
Originally Posted by TLover8888
thanks!
There is only 1 belt
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
Jboat
Sep 30, 2015 10:58 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
