Water Damage!!!!
T nice
Water Damage!!!!
i brought my car to have my system put in...and when i get back to the place they tell me i had puddles of water under my carpet...and in the trunk....anyone know why or how...and what can i seal up to stop this from happening
i too have this problems, I lifted up the spare tire and found a puddle of water. No idea why. At first I thought that it was because I had a 02 acura sign which did not use the whole, but then it does not seem right. Sorry I can't help you their
well i would resomend ripping apart your car and finding where its coming from. (or if your under warranty bring it to the dealer)
if you arent start out by climbing in the trunk with a flash light and have someone drive you thru a car wash to see if you can spot where its coming in
I have the same thing, at first it looks like condensation. The rim has water "droplets", but I had puddles of water on those dips in the trunk. Someone know where this water is coming from.
Hey fsttyms1, I had the dealer install my Comptech and Illumina combo. When I looked in the truck I found 2 screws/bolts. Could this be the culprit? These were small screws/bolts. I don't know where to look, unless I try to disconnect the back dashboard.
Originally Posted by fsttyms1
it may be different in the others. this hasnt been a comon prob on this forum so far. my recomendation is pull every thing out and see if you can trace where its coming from.
as for the screws? i dont think they would have any thing to do with it.
take you the side covers and look for traces of water, or look for areas where water might be coming in from. look for water stains like where it may have ran from. if you see water puddled up in the spare tire well start there. dry it out and then start hosing it down from the bottom side with water to see if you can see if/where its coming in. thats why i recomended taking every thing out of the trunk, (pull out your back seeat too) and have some one drive you thru a car wash (get the under body flush)
i dont know about a puddle but theres water releases under the trunk. my best guess would be rain evaportaed and condensated in your trunk. ive ripped my trunk apart to figure out HOWWWWW. i have a carpc i gotta look out for.
Tail light gaskets, and the rubber gaskets are the most common causes of water leakage into the trunk. Either of you do anything with your tails or have any body work done at all in the rear of the car?
Moderator Alumnus
Ya, i have the same problem but i know its from my swap out of the stock tails for the '02. Its only a little water and i have trunk mat anyway.....one day i'll seal them
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
