Washer Fluid Problems
Old Sep 6, 2004 | 06:27 PM
TLProspect's Avatar
It seems that when I go to release the washer fluid on the windshield, it barely squirts out from one side, and doesn't come out at all on the other. I was wondering what this could be due to (maybe wax getting clogged in holes where the fluid is released from?). Anyone else have this problem?
Old Sep 6, 2004 | 07:00 PM
ndawood's Avatar
Resident Troll.
i had the same problem... i had some wax in there.... try to clean out the nozzel with a toothpick or something.. that should do the trick
Old Sep 7, 2004 | 06:56 AM
joetroy's Avatar
I agree it's probably wax. I'd use a pin or needle rather than a toothpick cause if you accidently break off the toothpick in there, you'll really have a problem.
Old Sep 7, 2004 | 05:31 PM
TLProspect's Avatar
Thanks, I will try that
Old Sep 7, 2004 | 09:50 PM
Tom Blasing's Avatar
is the Mighty Favog
What year do you have? I don't remember which one this applies to but there is a TSB about washer hoses deteriorating and leaving rubber gunk on the windshield. Hopfully a chunk didn't break off in the lines and clog things up.
Old Apr 1, 2006 | 08:44 PM
amolvb's Avatar
9th Gear
I tried using a safety pin (I am positive it is wax since I remember getting some wax in there in summertime 2005) but in vain. What is the next level? I read on the web that one can remove the tubes from inside and spray some air. Anyone tried that? Any advice will be appreciated.
nanos
Nov 12, 2015 08:41 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
jfman55
Sep 5, 2015 02:55 PM
