Vibration problem
Old Mar 14, 2013 | 09:47 PM
CAB NY's Avatar
Tri State ViP Crew
Vibration problem
the problem is when i hit the brakes it feels like the front wobbles but not the same as warped rotors but i changed them anyway and still fill it so i had the front end checked and was told it was good so i want to know can it be a bad tire that might be damage because when i had the tire balanced i think one tire didn't rotate evenly because all these potholes tires and rims take a beaten
Old Mar 14, 2013 | 11:42 PM
Chevelle66's Avatar
I've noticed this as well, exactly. Everything has been checked out with the brakes and wheels.
Wonder if it's the booster or tranny or something, I have no clue lol
Old Mar 14, 2013 | 11:48 PM
hondakid23's Avatar
Motor mounts?
Old Mar 15, 2013 | 08:19 AM
CAB NY's Avatar
Tri State ViP Crew
Originally Posted by hondakid23
Motor mounts?
Changed them all last summer
Old Mar 15, 2013 | 09:08 AM
3.2TLc's Avatar
Double check the suspension, as worn wheel bearings or tie rod ends can cause some vibration. It's also worth the time to rotate the front tires to the rear and see what happens. Could be a tire is out of round or has damaged internal belts. Also the rim could be unbalanced or has a build up on it. Try the simple stuff first, make sure that the lugs are properly torqued.
Old Mar 15, 2013 | 03:50 PM
Chevelle66's Avatar
Originally Posted by 3.2TLc
Double check the suspension, as wheel bearings or tie rod ends can cause some vibration. It's also worth the time to rotate the front tires to the rear and see what happens. Could be a tire is out of round or has damaged internal belts. Also the rim could be unbalanced or has a build up on it. Try the simple stuff first, make sure that the lugs are properly torqued.
Hmmm out of all that stuff and more I'm left with wheel bearings and tie rod ends. thanks
Old Mar 16, 2013 | 11:46 AM
peewizzle's Avatar
my recently started doing this too! my front end and steering wheel only vibrate when i brake at excess of 65mph though.
i've replaced both outer tie rod ends, both upper ball joints and control arms, front pads, and gotten an alignment.
firestone complete auto care, who i get unlimited lifetime alignments from, said everything checks out fine. wonder what could be issue...
Old Mar 16, 2013 | 03:03 PM
3.2TLc's Avatar
Normally the first things to check for are warped rotors, unbalanced tires, worn suspension or driveshafts.
Just the process of inspection and elimination !
Old Mar 16, 2013 | 10:44 PM
CAB NY's Avatar
Tri State ViP Crew
everything was checked and was ok i was told both front bearings changed 2 years ago rotors 6 months ago but had the tire checked today and it is damaged has a lump in it that you can see when it spins so i put the factories back on and that stop the vibration i got when i was driven but the brake part is still there but the brake peddle doesn't vibrate feels smooth
Old Mar 18, 2013 | 10:15 AM
Es617's Avatar
I had this happen on Mine when i switched my rims. Tires were out of balance so the card would shake over 60. HAve you checked the calipers? Could be one of the pistons is not engaging properly
Old Mar 18, 2013 | 01:25 PM
412KING's Avatar
Have you replaced the strut rod bushings? I had to replace mine a few months agao and I noticed a considerable difference.
Old Mar 19, 2013 | 12:55 PM
peewizzle's Avatar
looks like i should just replace my bearings and bushings(excl. strut bushings) since i'm second owner and just hit 120k, is it a job i can just do in the garage on a sunday afternoon yall think?
pretty much everything else is new, new rotors from last summer, new pads last week, new struts and springs last summer, new upper ball joints/control arms in december, new outer tie rod ends in december..
Last edited by peewizzle; Mar 19, 2013 at 01:00 PM. Reason: front strut bushings already complete when i did drop
Old Mar 19, 2013 | 11:27 PM
CAB NY's Avatar
Tri State ViP Crew
since one tire has a lump when it spins and the others are starting to wear so i going to replace them but can the rear rotors cause this problem if they are warped the front was change in Oct. also i put the factories on the front and the same problem with those wheels on
Old Apr 11, 2013 | 10:39 PM
CAB NY's Avatar
Tri State ViP Crew
when i first had the problem i had a lot of vibration when driving and when i hit the brake it felt stronger so i check the front end over and over all good so i check the tires and they were out of shape i guess from the potholes everywhere so new tires vibration was gone while driving which was bad but now braking was vibrating and check the rotors the back was warped so changed those getting better but still a little vibration so i took a guess and changed one in the front with one i changed in Oct. and it was the right one vibration gone but it just seems funny that the rotors went bad after i used Green Stuff pads never know because the problem i had was the tire at first but the vibration became worse over time after the pads were change
Old Apr 12, 2013 | 08:30 AM
victus1's Avatar
Tire shops are known to warp your rotors when using those power guns to tighten the hell out of the lugs nuts. I always tell them to do it by hand.
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
