Using Seafoam in the tank improves power
I feel like i'm losing power and the rpm drops when I lightly gas it after stepping on the brakes and releasing. The car was driving real sluggish. So I seafoamed to the engine, and poured it in the gas tank. After the seafoam and in the gas tank, the car improved it's power. Once the tank was empty, the power was gone again. It doesn't pick up like how it did when I had the seafoam in the tank. So I'm assuming it's the seafoam in the tank that is giving the car more power.
Now, since that's what I came up with. If I am losing power, and seafoam is helping it, what is wrong with my car? Please give me some advice. Thank you guys!
seafoam the tank--cleaning doseage is 2 oz per gallon = 1 can to 1/2 tank
maitenance dose is 1 oz to 1 gallon,,1 can to full tank
It is cleaning the injectors and intake valves- plus carbon removal from the piston tops
May run funny after the first tank as its still blowing out crud or needs a bit more to complete the job
Spray TB or carb cleaner or deep creep- at the TB plate on both its sides and edges
If your spark plugs are over 70k miles its time for new ones, do the intake manifold vac port again then a week later change the plugs,, NGK Iridium IX for the gen2
maybe someone that had this problem can chip in, never had this problem happen to be. but i know that when i let off the gas on the high way my rpms drop down and then raise up but they usually drop down to around 800-900or so and then get back to normal.
different areas have 91 others 93 and 94--its just more additives to delay ignition
Doesnt matter as long as its 91 or over,,whatever they sell where you live
More octane above 91 doesnt make more HP on a stock TL, (non turbo or SC)
Seafoam- use a whole can in the intake vac port at TB with warm up and after drives.
1st timers should repeat in 1000-2000 miles, a month or so- to do a finishing job with more skill than before~
Then you should be good for a year on the manifold and throw a can in the full tank of gas after/every 5000 miles if you want. Good idea before a trip too
i actually felt that i had less power with seafoam in the tank and that the car didn't run as well, but now that i've refilled it feels smoother than before...guess i had a lot of gunk to burn off.
You feel?
Your RPMs are going to drop slowly if you're on the highway and you hit the brakes. The TQ is locked up and as you slow down the motor will to. If you jab really hard the car will downshift from 5th to 4th and if you're on the right grade and jab it just right you can get 5th to 3rd, or 5to4 to 3rd.
We need details like:
Mileage
Service history
Knowing how old your plugs are would help
Air filter?
The reality is there is nothing in seafoam that will give you more power. There is a lot of debate as to it's effectiveness at all. When we talk about 'feeling' less power it gets so subjective as to be a waste of time. What seafoam might help you do is restore your power however you wont feel it while it's in the tank running through the car. It's not a performance booster. It will over time, possibly remove dirt.
FYI - Nothing you put in your tank is going to cause you to develop more HP/TQ than the motor would on 91/93oc. It's all in your head. You'd have to burn something with more energy in it than gasoline, which you cannot legally get or burn in your car.
If you really think there is something wrong with your car. Inspect the follow:
- Plugs
- Air filter
- Clean TB
- Check valves
It's all in your head. As is the octane boosters which are horrible for your plugs.
No matter how much higher the octane rating is. No more power will be developed beyond 91oc.
Not really possible. Most cleaners have lower octane ratings than 91 fuel and some even come with warnings as such. Stating 'Should not be run with regular fuel'.
Your probably right but the car seemed to have just a tad more power when running techron or even some seafoam. Then again I had a crack in my header for a bit so that may have something to do with it. I never run octane boosters.
Winter gas can be very different from station to station. I have experienced my car running poorly=less power, rougher idle etc. After running out the current tank of gas and refilling with a different brand=it all improved. So change brands and see what happens first.
You feel?
Mileage
Service history
Air filter?
- Plugs
- Air filter
- Clean TB
- Check valves
Mileage
Service history
Air filter?
- Plugs
- Air filter
- Clean TB
- Check valves
"Your RPMs are going to drop slowly if you're on the highway and you hit the brakes. The TQ is locked up and as you slow down the motor will to. If you jab really hard the car will downshift from 5th to 4th and if you're on the right grade and jab it just right you can get 5th to 3rd, or 5to4 to 3rd." --- I totally understand what you are saying, but what I'm trying to say is, this did not occur when I first had the car at 50k 60k miles, it didn't act like this. That's why i figure something may be wrong??? I've had a problem with the throttle cable before, and when the dealer fixed it, the car was soo powerful, now, it just doesn't have the same pull to it.
Mileage: 89k miles (I want to add, this problem hasn't just recently occured..if you look at my other posts, i've complained about this almost a year ago..)
Service history( Oil changed every 7k miles)
Knowing how old your plugs are would help ( plugs were replaced after I seafoamed)
Air filter? (Stock air filter, haven't changed it)
- Plugs - plugs were changed after i seafoamed
- Air filter (Stock air filter, haven't changed it)
- Clean TB- Just bought some throttle body cleaner, no change
- Check valves- As in check the valves? After I changed the spark plugs, i noticed that the valves are tapping a bit louder)
thanks again rob
I've already changed types of gas, chevron, shell 76..winter summer, spring fall, it doesn't matter, same result.
anybody ever drive a stick, when you put it in the higher gear than it's supposed to be in, and u step on the gas pedal, it'll rev really low and won't produce a lot of power, but you keep your foot on the same amount until the rpm slowly rises up, you then get power, well that's what my car's feeling like.. just struggling until the rpm gets higher, which i did not have before..
What type of plugs are U using ? I change mines to NGK iridium and got the same symptoms ...MPG drop , less power , valves knocking louder , very sluggish ......
So decide to go back to old original plugs and performance is back .
After changing the plugs did you notice any problem or change ??
No I did not check the gap before installing the new iridium plugs ...but when I remore them ,all 6 are running a bit rich ...the car idles OK with them but lost power when accelerate
I still do not think the gap is the problem ....maybe iridium does not has enough spark to burn all the fuel ( running rich ) .
Maybe double Platinum is better then the Iridium that might explain the extra cost to get
them .
them .
go research iridium plugs and then stop talking smack
its a better metal- plain and simple. Modern mining techniques made it avaliable to the public- not just for race cars and airplanes anymore!
We dont need Lazer plugs- all this means is the type of weld used to join the parts
double platinum is not stock- single is
NGK plugs comes with a cardboard protector on the end- if its not damaged the gap is correct. Dont mess with the gap !!!! you will damage the plug
