Using Seafoam in the tank improves power
btw- you used a double double strength seafoam in the gas tank- 2 oz per gal is cleaning does- you used 4 oz per gallon
Could have stirred up a bit too much crud all at once
Repeat proper gas tank method with 1/2 tank and 1 can in the intake vac
How much did you use there? which place did you think was the vac port?
I checked the gaps..only one of them were off, so I fixed it to the proper gap.
go research iridium plugs and then stop talking smack
its a better metal- plain and simple. Modern mining techniques made it avaliable to the public- not just for race cars and airplanes anymore!
We dont need Lazer plugs- all this means is the type of weld used to join the parts
double platinum is not stock- single is
NGK plugs comes with a cardboard protector on the end- if its not damaged the gap is correct. Dont mess with the gap !!!! you will damage the plug
What type of plugs are U using ? I change mines to NGK iridium and got the same symptoms ...MPG drop , less power , valves knocking louder , very sluggish ......
So decide to go back to old original plugs and performance is back .
After changing the plugs did you notice any problem or change ??
Sounds like the valves, or it may be arcing someone suggested?
https://acurazine.com/forums/showthr...seafoam&page=4
The picture of the Seafoam can showed a 16 oz can, and that's all they sold at the Auto Zone here.. I guess I used too much. Yikes.
But all of this still doesn't answer my main topic: Using Seafoam in my tank makes my car repond better, thus makes it have more power immediately..
Does the seafoam in the tank really do something then? This can't be all in my head..it's a crazy difference.
NGK: Double Platinum (original equipement Manufacturer )
Extra Long Life Double Platinum Plug,
NGK extreme life plug. By using the highest platinum content in the industry, NGK has created an extremely long life spark plug. Laser welded platinum tip on center electrode and platinum tip on the ground electrode. The center electrode is taper cut which aids in focusing the spark while reducing the voltage necessary to start the combustion process, this will provide better throttle response, improve efficiency and allow a smoother idle. Stainless steel washer reduces plug self-backing
According to NGK ..we have a double platinum as original equipement
http://ngk.com/results_app.asp?AAIA=1377008
Myta : Why don't you try to reset the ECU by pulling the #13 fuse .Remember to do it with the engine cold :
Start the engine and let it warm up ( no load ) until both fans run twice (very important )
Then let it idle with no throttle for 10 minutes ....then you're good to go .
and gen3 comes with platinum as its a better plug- so we can use it too
I dont recall if the oe were dbl or singl- didnt care~ went with the acurazinr advice of iridium ix for gen2
how much was the plug gap off? too wide or shallow gap?
you could have exchanged it at the parts store for a perfect one
do a fuse 13 reset-- I had not heard of waiting for the fans--isnt the pass side one controlled by the AC -and in extreme temp demands it backs up the driver fan?
When I have burped the radiator per the book it had one fan required for sure
the seafoam diy needs fixing - we used to do 1/2 in 1/4 tank but when you refill at the light - not much cleaning has been done and then its heavily diluted-below cleaning strength
1 can in 1/2 tank seemed easier for people to get the best results on the first try
Doing it double that may have increased power slightly for that tank
Try it the correct way and see how it goes
You said you cleaned the TB plate too- with carb cleaner??
the end result was defective plug gap- not iridium are bad for the TL
I quit my job as Quality Control Inspector for stupid problems in Life--
Good to see someone else has found the one in a million problem--thanks for taking over--much appreciated~
Rajca, any chance it could be the tranny? When on the freeway, then having to brake, then i wanna gas it lightly, the rpm drops and very sluggish
One suggestion is to drive it in auto-stick manual mode. See if you can make the problem go away by shifting manually. This removes the TPS from the equation. Also you can check your TPS with an OBD2 scan tool by view the live data as you exercise the gas pedal thru it's full range. Graph it may be better as it may catch strange blips if it is getting flakey.
Another *off the wall* suggestion is to put 87-89 octane for quarter of a tank. If seafoam does lower your overall octane, then this may cause the tranny to do different things because the timing is now retarded to avoid pinging. The perceived improvement might be that the tranny is shifting properly in this mode.
One last comment - is your check engine light on?
When you lift off the gas the tranny may up-shift (if it's not already in 5th gear). Depending how aggressively you get back on the gas the tranny may downshift causing your rpm's to jump up also. If it's not down-shifting it might be a tranny problem or your ecu doen't know you want to go faster. Your ecu knows this because of the Throttle Position Sensor. So your TPS may be getting flakey. If the TPS check out okay, and your rpm's still drop (i guess this is an upshift on the tranny) then your tranny is whacked out, or maybe our TQ is doing weird things.
No. No check like on right now.
Keep in mind, the rpm dropping and low power output happened way before doing seafoam..
Lets elaborate on this a little. Do auto-stick mode while cruising at 40mph and in 5th gear. Now floor it and down shit to 3rd as fast as you can. Is it still sluggish? Does the tranny shift to 3rd in less than say 2 seconds?
Yep i saw your other posts. I don't think this is a seafoam problem. Have you checked your ATF fluid lately?
I hope this is the answer you need
I feel like i'm losing power and the rpm drops when I lightly gas it after stepping on the brakes and releasing. The car was driving real sluggish. So I seafoamed to the engine, and poured it in the gas tank. After the seafoam and in the gas tank, the car improved it's power. Once the tank was empty, the power was gone again. It doesn't pick up like how it did when I had the seafoam in the tank. So I'm assuming it's the seafoam in the tank that is giving the car more power.
If I am losing power, and seafoam is helping it, what is wrong with my car? Please give me some advice. Thank you guys!
you know this HOW? from where? its a bit off~
but welcome to the forum anyway!
seafoam doesnt get into the oil in mass quantities when done thru the gas and intake vac methods,,a tiny bit via normal piston ring bypass- but not huge amounts that would be an issue to the oil..some gas gets in the oil too....thats normal combustion effect
If you put it directly into the engine oil and idle or drive as desired,
then change oil and filter..the filter will be full of sludge allright- but not from seafoam particles- from sludge and crud that WAS in the engine oil passageways, pan and pump pickup screen.
If you want to use it in the oil and do some driving to cirulate it and really scrub- then its good plan to install a new oil filter so it can catch all the particles of many sizes that will be coming at it--it will have get lot of crud in it- cut one open and see
then do an oil and new filter change
In case you havent noticed,, its a liquid- low on the chart of stuff from the oil barrel- its 100% petroleum product.
can be used in aerosol form as engine starting fluid, excellent household lubricant and a thousand more things--sold as Deep Creep in parts stores. pure seafoam in a spray can, with more room on the can for more uses and expanded directions on use for the engine-intake methods
acuratl26
Apr 23, 2020 07:30 PM
DerrickW
Nov 15, 2015 05:52 PM
