Urgent: V-afc Ii Install Problem
Old Oct 19, 2004 | 10:48 PM
Tunaboy's Avatar
Who Dis Is?
I just got done hooking up my v-afc II to my ecu and got everything puy back together. I haven't programmed the V-afc yet and I took it for a test drive just to see how my car overall rean. Well everything seemed fine and I gave it a little gas and the throttle started to studder. No matter what the RPM's do NOT go above 4000. If anyone knows what to do so that I can drive it around without problems before I get it dyno tuned?
Old Oct 19, 2004 | 11:23 PM
@cUr@-TL's Avatar
'99 Acura 3.2TL
how many times will we have to say this:
if you do not know what you are doing, take your car to a shop and have them install and dyno tune the v-afc.
now what i would do is slowly drive to a reputable shop and have them tune it for you...
-justin
Old Oct 19, 2004 | 11:42 PM
REV-01's Avatar
you need to set certain settings based on what type of car you have in vafc before you start the motor
Old Oct 20, 2004 | 10:49 AM
dands99tl's Avatar
The map sensor needs to be set to type 06 in and type 06 out. Other than that, you will have to check the manual to make sure the basic settings are correct.
Old Oct 21, 2004 | 02:54 AM
touchdown's Avatar
This should be a lesson to ALL people who install parts without reading any of the supplemental liturature. With ApexI electronics you need to program the electronic piece for the specific car BEFORE you EVER start the car. Otherwise the electronic piece is sending the wrong info to the ECU and the cars computer gets very confused.
Heres the manual, set the car up right... http://www.apexi-usa.com/productdocu...ics_vafcII.pdf
Old Oct 21, 2004 | 03:27 AM
Beeza's Avatar
1 B3AKOHE
Can you guys tell me exactly how this helps the car ??
cycdaniel
Dec 17, 2019 10:58 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
HOWELLiNC
Sep 5, 2015 03:09 AM
NSolace
Sep 3, 2015 08:02 PM
