UR crank pulley? for 99 tl
I need 2 more gears
I can't seem to find a UR crank pulley for my 99 TL. Should I look under 99 Accord V6 or will a 00-02 TL UR crank pulley fit my 99? Help I want this mod badly!
I need 2 more gears
BTW is the Ultra S my best bet for power gains? I have a system and the 12V charger series sounds good too, but I'm getting a power cap soon so I done have worries about lights dimming. Has anyone dyno'd there car after this mod? What power gains were seen or felt after this mod?
Boomer SOONER
Smitty's Moral Police
From Crutchfield (various versions available elsewhere):
A capacitor, which stores electrical power to deliver on demand, could help. A cap cannot correct a battery or alternator problem, but can alleviate some of the intense current draw associated with brief low frequency musical peaks (like hard bass hits).
Typically, the main reason that you would want to add a capacitor to your audio system would be to gain better sound quality, especially from the low end of your system. Low frequencies require more power in order to be reproduced at the same level as higher frequencies. The capacitor improves the sound quality by storing electricity from the battery (which is provided by the alternator), and releasing it very quickly when the amplifiers need it. The capacitor then recharges from the battery. As you can see, the capacitor helps alleviate some of the direct stress that would normally be on the battery and alternator, but if there is a power problem in the vehicle it's best to go right to the original source and upgrade the alternator
If your lights dim either when the bass hits or when multiple accessories are turned on, then the best thing that you can do to fix the problem is upgrade the alternator. In an automotive electrical system, the alternator provides all of the electricity that the vehicle uses. The battery is maintained by the alternator, and stores enough electricity to start the car and run the accessories for a short time while the engine is off. If a stereo system that has a high amount of current draw is added to a vehicle, this can possibly be too much of a load on the factory alternator, especially if the load is near or over the alternator's maximum output capabilities.
I need 2 more gears
I have 500 watts rms total running to my subs 250 each. I don't experience dimming of lights, but if I add the UR Ultra S will this cause my lights to dim? If not I am all set. I did want to know if my increases will mirror the cl-s or the accord v6. I have a 99 tl. Will just the crank pulley be what I need to gain power and not lose too much current?
Boomer SOONER
acuratl26
04-23-2020 07:30 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
