Unable to turn the key
Old Feb 16, 2009 | 08:52 PM
unix's Avatar
4th Gear
Unhappy Unable to turn the key
Hi,
I could not TURN the key to start the engine. The car is of 2002 TL and is in good shape so far and maintenance is being done so regularly. I just came back from work an hour ago and could not start the car now.
Any help appreciated and thanks for your time.
unix.
Old Feb 16, 2009 | 09:30 PM
cominfromafar's Avatar
Casper
Wiggle the steering wheel while trying to turn the key. If you left the transmission in something other than park, shift it to "N" as well. I doubt it is necessary but press on the brake pedal a bit while trying to turn the key as well.
Old Feb 16, 2009 | 10:21 PM
nayaab88's Avatar
make sure its not in gear.
Old Feb 16, 2009 | 11:24 PM
unix's Avatar
4th Gear
Hi,
Thanks to both of you. The car is in parking gear and I could not shift it. I tried to start with pressing the brake which did not help. I will try steer the wheel and will be back.
Thanks once again for your help and time.
regards,
Srini/-
Old Feb 17, 2009 | 10:44 AM
unix's Avatar
4th Gear
Hi cominfromafar/nayaab88,
Thanks for the help.
I was able to start the car as usually when I steered the wheel a bit. Thanks for your help. Any thoughts why this was happened ?. My life would have become miserable if this is happened when I am far away from my home.
Have a great day.
Unix.
Old Feb 17, 2009 | 11:05 AM
01tl4tl's Avatar
dont park with the wheel cranked hard all the way to one side- that engages the steering lock at a bad angle and you get stuck- as you now know
If it happens to anyone else- just turn the wheel slightly to relieve the tension
Old Feb 17, 2009 | 06:37 PM
Razzi's Avatar
T-Swzy
yeah my old camry used to get locked like that too.
also, a worn key wont be able to turn either. it'll unlock the doors but wont turn in the ignition. be sure to keep an eye on that too
Old Feb 17, 2009 | 08:47 PM
nhn23's Avatar
I live in
its okay. my girlfriend's friend's rdx did this and she had no idea what happened..she called asking why she cant start the car and was zzin out sayin "its a brand new car, what did i do?! what did i do?!" lol i thot it was funny
Old Feb 17, 2009 | 09:13 PM
newperson's Avatar
There's no Acura in
Happens to me every now and then. Except my old solution was just to turn the key harder. After turning the key harder and seeing the steering wheel jerk once the key successfully rotated, figured the steering lock was the reason and now I just play with the wheel a bit.
Old Feb 18, 2009 | 09:32 PM
Gray03's Avatar
I think this is normal and happens if you turn the steering wheel after you've removed the key (or put it in "Lock"). Its a steering lock, supposedly for anti-theft. As you've discovered, moving the steering wheel while turning the key will put everything back to normal.
rockyboy
Aug 4, 2024 10:35 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
Sep 17, 2015 09:01 PM
PortlandRL
Sep 14, 2015 12:01 PM
