type-s TB
Old Jan 6, 2005 | 08:20 AM
soccerbenk's Avatar
type-s TB
will a 2001 cl type-s thottle body work on my 1999 tl is this the same thing as the newer type-s TB's?
Old Jan 6, 2005 | 08:26 AM
NSXNEXT's Avatar
Yes, same thing as the 02-03 TL TypeS.
Old Jan 6, 2005 | 08:37 AM
soccerbenk's Avatar
thank you very much this would have to be the only reliable forum in the world where i can post a question and get an answer within 10 minutes
Old Jan 6, 2005 | 11:29 AM
etxxz's Avatar
@ slide or die @
:'( i know :'(
btw* did you find one?
Old Jan 6, 2005 | 01:15 PM
z3Ro's Avatar
Mr. 2tone
i have a question some what related to this...i bought a AEM CAI for my 01' TL-P...would that also fit on a TL-S TB??? or would i have to get a new CAI?...
Old Jan 6, 2005 | 01:18 PM
1fasttl's Avatar
The Type-S tb is 3''. Your going to have to get an adapter from 2 1/2 to 3''
Old Jan 6, 2005 | 02:27 PM
z3Ro's Avatar
Mr. 2tone
an adapter?...can u give me n xample?...
Old Jan 6, 2005 | 02:30 PM
1fasttl's Avatar
Sorry i was talking about a silicon adapter that has a different size on each end of it. So instead of have the same size connector like your original one on your intake this one has two size's.
Old Jan 6, 2005 | 02:39 PM
99TLHeather's Avatar
1fasttl, what has to be modified on our TLP to gain increases in whp if installing a CLS/TLS throttle body?
Thanks!
Old Jan 6, 2005 | 02:44 PM
1fasttl's Avatar
I'am not sure about the TL-P manifold, but you might have to bore out the manifold were the tb bolts up to just to match the same size diameter of the S tb. I could be wrong as i know if you really want to gain some extra hp just go with a complete TL-S/CL-S manifold. And of course you have all the bolt-ons and for and easy 15-20hp you can always put in a test pipe like i did. The only down fall is you'll have a check engine light that's all but wow will you notice a difference.
Old Jan 6, 2005 | 03:11 PM
From all the bolt ons that I already have, if I get the UR Pulley, full cat back, TLS/CLS throttle body and TLS/CLS manifold/bore out manifold, I would be able to increase my hp an add'l 15-20hp. This 15-20hp does not include my headers and intake correct?
Old Jan 6, 2005 | 03:14 PM
1fasttl's Avatar
That sounds about right. And that's with removing the cat-converter
Old Jan 6, 2005 | 03:16 PM
1fasttl, Thanks for the info
Old Jan 6, 2005 | 03:18 PM
1fasttl's Avatar
No problem anytime
Old Jan 6, 2005 | 04:05 PM
z3Ro's Avatar
Mr. 2tone
any way of disabling the check engine lite...or bypassing it?
Old Jan 6, 2005 | 04:08 PM
NSXNEXT's Avatar
It's actually 2.75" but who's counting.
Old Jan 6, 2005 | 04:31 PM
1fasttl's Avatar
Yes there is http://www.casperselectronics.com/Me...ory_Code=honda
Old Jan 6, 2005 | 05:05 PM
soccerbenk's Avatar
hey i just ordered the type-s throttle body for 135 shipped from texas to mass. not bad. i was wondering if on my 99tl with the type-s throttle body if i could just buy a type s cold air intake so i would not have to use a conversion pipe. Will the CAI meant for the acura tl type s fit on my 1999 acura tl with a type-s throttle body?
Old Jan 6, 2005 | 05:28 PM
1fasttl's Avatar
No a TL-S intake will not fit cause of the VSA TB. The TL-S aem intake is too short because of the VSA.
Old Jan 6, 2005 | 05:56 PM
z3Ro's Avatar
Mr. 2tone
where would i even find the adapter? is there a specific brand?...or is it just a sleeve?
Old Jan 6, 2005 | 05:58 PM
1fasttl's Avatar
You can try like pep boys or any local tuner shop or maybe even home depot plumbing section
Old Jan 6, 2005 | 06:24 PM
jleon2516's Avatar
Tristate Vip Crew
Where did you order it from? Thanks!
Old Jan 6, 2005 | 06:54 PM
Hey soccerbenk, do they have any more?
Old Jan 6, 2005 | 08:29 PM
etxxz's Avatar
@ slide or die @
i'll check and let you guys know
Old Jan 6, 2005 | 08:57 PM
soccerbenk's Avatar
i dont know if they have anymore thank you 99tlheather for the referal tho it was much appreciated
Old Jan 6, 2005 | 10:42 PM
etxxz's Avatar
@ slide or die @
yeah, he da man...
BUT, there's no more available...i e-mail and called em up, both had the same story. I filled a request form on like 10different networks, hopefully atleast 1 will respond and the rest i'll donate to acurazine (refer, anounce, resell...notn's free ho!)
Old Jan 6, 2005 | 10:48 PM
ncxvtguy83's Avatar
Do you know how short it is? could we possible just use a longer extention of somesort?
Going by Aem's website for Cold air intakes, all 1999-2003 base model TL's all use the same part number. 02-03 base TL's have VSA, so why would they still use the same part number with the 99-01's (tcs)? Just trying to confirm this info. I also have a 99 and want to install the type-s TB, but i was thinking of getting a Type-s CT icebox. I wasn't sure if it will fit due to a possible difference in design of the base and type-s TL.
Acura TL 2002-03 A/T Only Type-S 21-419
Acura TL 2000-03 3.2L 21-416
*anybody knows? please chime in. Thanks
Old Jan 11, 2005 | 09:45 PM
ncxvtguy83's Avatar
anyone?
Old Jan 16, 2005 | 03:05 AM
z3Ro's Avatar
Mr. 2tone
ok...the lady at the dealership is st00pid n made me think bout it even more...im just double checking....i have an 01' TL-P...can i replace my TB with a 02' TL-S TB...or mayb a 02' CL-S TB...which 1 is better...thx...i wana get this ordered rite away...btw...i have an AEM CAI for my TL-P
Old Jan 16, 2005 | 07:41 AM
blackonblack02's Avatar
I have an 02 base TL and it has TCS not VSA
Old Jan 16, 2005 | 05:53 PM
ncxvtguy83's Avatar
Both the TL-S TB are the same. As for the AEM CAI, you will need a reducer from the 3" Type-S TB to the 2.75" Cai.
Jul 16, 2017 07:33 AM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
DerrickW
Nov 15, 2015 05:52 PM
