turning off check engine light
how do u turn off the check engine light? i did it before but i forgot the process. I remember it had to do with the reset button on the dash. I am getting my car inspected this month and i know it cant be on or i will fail.
Is it the Check engine light or Maintenance required light?
If its really the Check Engine- that means something is wrong with the car and you need to go to a parts store that will pull the engine computer codes for you.
If its ready for an inspection- thats usually the time it needs an O2 sensor or EGR cleaned!
yeah that is wut the codes r for. i already got it scanned at auto zone and it said o2 sensor and egr valve. im going to replace them just i am wanting to go to inspection tommrow with no check engine light on.
you can disconnect the battery for a few minutes to clear codes. but it your in an emissions area were they analyze 5 gas and check you computer, your monitors will not set if you have an engine or drivability conern still present therefore not letting you pass your state inspection.
If there is a problem with something(which there is if your getting a code) you can reset it but it will come right back and most likely show up on any test done. Get the parts fixed first.
Clean out your EGR and reset the computer to see if the light comes back on.
http://www.in.honda.com/Rjanisis/pubs/SB/B00-004.PDF
Also we still need to know if this is a smog test or basic visual inspection?
Of course do as kris said and replace the bad parts.
You also need to drive a day or 2- like 100 miles to get all the parts cleaned out (use Seafoam) due to bad O2 sensor, and get the computer to decide all is well.
Then go for testing and pass no prob
HeloDown
09-08-2015 06:51 PM
