Transmission flush
Transmission flush
I have an 2001 TL with 70k, tansmission fluid is brown. Do i need to replace the gaskets and the filter as well or just the fluid. If i do need to replase the gaskets, what are they called
On the way!
Received 1,080 Likes
Just pop the drain plug under the car and let all that brown goodness drain from the tranny.
It is not recommended to "flush" our tranny. Just a simple drain and fill.
Thanks a lot to both of you! I just got off the phone with an Acura dealership and they told be the same thing. I was about to get ripped off by an AAMCO shop, they told me i need to replace some gaskets and it will cost me lot of $$$
you can do it yourself, its just like changing the oil. Pull the plug, let the 3.somethign quarts come out, put the drain plug in and fill er back up.
Thanks fsttyms1,
I was just about to ask what was involved..
Bob
Bob
You dont think that AAMCO power purge would be better?
joflewbyu2
10-08-2015 11:16 AM
