transmission failures
I was just curious if there is a general time/mileage that the transmissions tend to go on our TLS. I know that it is probably different but is there a typical window that it tends to happen??
not that i know of...a friend of mine with a type-s and 140k miles wasn't aware of any transmission problem...on the other hand i think someone on this board is on his 8th tranny?
mine is a tl-p...first tranny lasted till 18k, second lasted another 80k, hopefully this third one lasts longer
Yeah its been different for everyone IIRC. However I don't think there has been a report of failiure since the last revision, at least not on here that I have seen. So hopefully they are a bit more reliable now.
what are you blind? there is a whole thread dedicated to post 2/05 replacement failures!
Yes they are better than the original but you have to guess that the warranty rebuilts are test platforms for changes to the general production model~
and may themself also fail-under warranty
My insider tech says anything over 50k miles for an original trans is ~right on schedule~
meaning prone to failure for a gen2 trans
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
My tranny on my 01 CL-s went at 36k and 99k I now have 161k and this tranny is holding up fine but i baby it and tranny fluid change 6 quarts every 25k!
ohhh you have no understanding of the situation- I see, they dont replace the trans unless its failed
need to do some thread reading
The recall is to install an external oil jet kit- if not done get it done
different issue than the extended warranty to 7+9month /109-(114.5 vins with odometer error court case)
Not all 03s are covered on the 7/109- need to check your vin
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
