Transmission
Old May 11, 2014 | 12:06 PM
2ndgentlMike's Avatar
Transmission
Hey guys, i know our cars have a notorious transmission problem but can someone explain the details and symptoms of it to me. Im starting to notice a shake in my seat around 2500-3k rpms in 2nd and 3rd gear, getting a little scared, I'm hoping my seat is just lose or some bs but i have a slight gut feeling that the tranny is giving out. Thanks for the help.
Old May 11, 2014 | 12:09 PM
Skirmich's Avatar
Completely Unrelated to the trans issues... Shakes mean you got to check your Mounts.
Trans issue is pretty obvious (RPM Fluctuation and Slipping shifts) other than this is not related to a failing trans.
Old May 11, 2014 | 01:11 PM
Ahhh thats a huge relief, thanks
Old May 14, 2014 | 08:53 PM
update, the car idles a bit high on a cold start but after its on for a but it goes down to a normal idle. Also its the whole car shaking not just my seat
Old May 14, 2014 | 09:23 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Worn axles check for play, Loose lug nuts tighten them or Torn engine mounts.
Old May 15, 2014 | 07:20 AM
3.2TLc's Avatar
Talking S.ssha....akk...ki.i.ing
Yeah, check the mounts and also find the reason why the idle may be high or rough.
Old May 15, 2014 | 08:39 AM
TLZINE99's Avatar
Listen to the trans for whirling noise during cold start, if u hear loud noise thats symptoms for ya.
Old May 16, 2014 | 10:36 PM
JDM_DoMo87's Avatar
7th Gear
I have a transmission issue. ... When I drive my tl type s my car get stuck in 2rpm then kicks hard wat should I do.
Old May 17, 2014 | 07:27 AM
fsttyms1's Avatar
The trans gets stuck in 2nd gear or wont shift beyond 2k rpm?
Old May 18, 2014 | 01:34 PM
TLZINE99's Avatar
U replace trans.
knight rider
Mar 4, 2016 08:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
