Tranny Fluid
From: Broooklynnnnn Babyyyyyyyy home of the hottest italians!
Tranny Fluid
I have a silly question...where does the tranny fluid go? in the same hole where u check it? Also my check engine light just went on the day after i checked the fluid to see it was dry im scared now...anyway the reason i ask is i cant find a skinny enough funnel to get in the hole where you check it pls. help
Welcome to the forum.
There is a Filler bolt on the top side of the tanny for fluid. If you have brought your car in for teh recall work then you need to remove the oiljet kit to fill it. Is it the check engine light or maintance required light?
You don't fill it throught the dipstick hole. There's a bolt that reads ATF on top of the tranny. That's where it goes.
If you had the oil jet kit done, you would not see that bolt because the oil sprayer goes there.
well both the check engine light is on and maint. required and i just went to a mechanic to have him check the fluid and he said it goes in through the dipstick hole which is where my bf put it in and it stayed there so i guess thats right?? im so effing confused why do women know nothing about cars!?!??! anyway most likely im going to take it to someone my bf know thats a mechanic for him to check it out this weekend...thanks everyone..oh and to NSX smart guy i just joined i didnt know how to search so thanks =)
Originally Posted by pmptx
I just did mine, and it was easier to fill through the sensor just behind the oil jet.
Originally Posted by fla-tls
Yes - you can just bring it in. The dealership should be able to look up your VIN and see what recalls have been done on it already.
There have been several recalls - not all are tranny.
You can find out what recalls are on your car by going to Acura Owners Link
If you bought the car used, you'd never know which ones were already fixed. The dealership would have to run the VIN and tell you. You can probably get that done over the phone, id think.
SidhuSaaB
May 30, 2020 12:40 AM
lanechanger
Oct 13, 2015 10:56 AM
