tranny drain bolt
tranny drain bolt
does anyone have a pic of it? i dont know where it is.
i am guessing its the cirlce bolt with a square on it.
if this is the bolt then what do you use to get it off?
wow. i want to really thank you fsttyms1 and tlmugen. for actually replying to what i asked. also an extra thank you to fsttyms1 cause you have been great in helping me out lately.
i more thing what would i use to get that bolt off? i have no idea what kind of tool has a squared off tip, cause i only have socket's and allen wreches. ihave never seen anything that could that that bolt off.
oh yea also. could i just do the following?
drain
fill
turn on car and go through gears
put in park again turn off car
drain... and so on?
or do i actually need to take the car out for a drive? t
the reason i ask is cause i jack my car using 2 jacks cause the stock wont lift front end up so it is really exhausting to lift the car up. the horor it takes just to lift the front end gives me migrains.
drain
fill
drain... and so on?
When you drain & fill, about 3 qts comes of fluid comes out (I think the trans total capacity is about 7.5 qts). If you do the d&f a couple of times you will have changed out nearly all of the fluid. I'm not sure I understand why you're asking if you should cycle the trans through the gears or drive the car (if it's to mix the fluid properly, I prefer to drive the car). Bottom line is the trans only needs a d&f every 45K miles for normal conditions; there's really not a lot more you can do (apart from the extended warranty oil jet fix) to keep the trans healthy.
Originally Posted by suj220
thanks for the pics everyone. is it possible for someone to take a pic of the fill hole? i have the jet kit installed so i am not sure if I should remove that or not??
i bought 12 quarts of tranny fluid so i am planning on d&f 4 times. I got my tranny fluid flushed by a dealer at about 15,000 miles i now have 28,000 and the trans fluid is brown. so i am changing it out completly now, this is sad that it doesnt even last 30,000 for changes. If you were to any of my family memebers to change the tranny fluid every 20,000 miles they laugh and 10,000 they would call you stupid. Yet we all know this tranny is just pathetic so every 15,000 is not suprising to me.
omg. wow now that is just ridiculous, its just not right to charge 21 dollars a quart.
i got mine for 3.99 a quart.
try your all your local acura dealers and honda. i was suprised that it was acura offering the 3.99/quart.
no kidding it should be less than 4 bucks a qt!
Kris is a great guy, and we can all learn a lot from him. You rock buddy...
I'd give you more rep points, but I already gave you too many!!! Don't worry, as soon as I spread the wealth around, I'll be back to give you more.
Take care.
MetalGearTypeS
Aug 29, 2016 08:28 PM
