Traction Control question
Old Sep 27, 2003 | 11:55 PM
bdv687's Avatar
What does turning of your traction control do (someone mentioned that they did it right before a race), and how do you turn it off?
Old Sep 28, 2003 | 12:13 AM
Tom Blasing's Avatar
is the Mighty Favog
Turning it off will no longer allow the engine to decrease power to the wheels when they start to slip. Turning it off allows a higher engine RPM and torque when the tires finally grip again.
Old Sep 28, 2003 | 12:16 AM
bdv687's Avatar
How do you turn the traction control off?
Old Sep 28, 2003 | 12:27 AM
is the Mighty Favog
There should be a button near the cruise control on the dash panel to the left of the steering wheel marked TC or VSA or something like that. When it's turned off you'll probably have the yellow light come on in the instrument cluster with an exclamation point in it.
Old Sep 28, 2003 | 03:07 AM
wait...so does that mean when you push but button DOWN, the traction control is off? cuz then the button its UP, the TCS light flashes when i slide my wheels on a wet road.
Old Sep 28, 2003 | 03:49 AM
brado's Avatar
new wheels = old school
yea, that means the tcs is being engaged at that moment. it should only be working at low speeds...nothing over 40 mph
Old Sep 28, 2003 | 03:51 AM
brado's Avatar
to be more thorough, when the button is pushed in, the tcs is turned off and there should be a little tcs sign light up on your guage cluster. when button is not pressed down, the tcs is on, and ready to be used. and when it is being used(sliding), it was light up as it is engaged off and on. hopefully that didnt confuse you more.
Old Sep 28, 2003 | 03:58 PM
thanks. i always thought it was the other way around.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
datadr
Sep 12, 2015 09:12 PM
gqdabien
Sep 8, 2015 11:41 PM
Charlespsu
Sep 2, 2015 09:54 AM
