Torgue wrench needed?
actually the needle type wrenches are considered to be more accurate. your supposed to use those when doing engine work.
but they are a little annoying to use. i use a click type.
no need to torque the drain plug
Thanks for the info. This weekend I went to my local Sears department store and saw two types of dial and click torque wrenches, 25-250 inch-lbs and 15-75 ft-lbs. They are both $70 each. The 15-75 ft-lbs is a little bigger. Do you think it's worth the money getting the 15-75 ft-lb to do most of the Do-It-Yourself jobs?
I have the larger sears torque wrench and have been happy. I would use it for both the wheel nuts and the oil pan. It won't quite make it for the lug nuts but you can turn th nut just a little more for more torque.
The oil pan nut is very easy to strip and about $800 to fix. I use a torque wrench each time.
steve
steve
Same holds true with the lug nuts. 80 ft/lbs doesn't seem tight enough when you first torque them to spec, but it is fine and I've never had one come loose. Tire places use an impact wrench and I've had my car come back with lugs torqued well over 100 ft/lbs. Those are a b!tch to get off without a T-wrench or impact wrench yourself.
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
