TL tranny
ck the diy list- iirc there is info on what other trans fit with little effort
Nothing is direct bolt in or we all would be on it!
diy list link https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
and welcome to acurazine!!
just wait here for the real experts on this subject
or use search function ,,try alternate trans
its been discussed before, a scroll thru the main threads or the problems or performance section should yield info
lots of different transmissions work. Common options include Odessy's, gen3 tl's, cl's and Accord v6 models.
Its a common misconception is that they don't work with one another.
A J-series motor usually works with a j-series mated transmission.
Usually the sensors or solenoids need to be swapped from the old transmission into the new transmission (sensor connections not compatible).
The old senors usually fit perfectly into the new transmission.
Even if the mount bracket itself is different, the mounting threads should be the same right? so that shouldn't be an issue either?
Thanks again guys, you guys rock.
I would do some searching to see what others have done in the past and focus on the threads where the person details the process/what their situation was and what happened.
Their out there, just gotta go find them.
Pham Alvan
03-16-2016 09:17 AM
lanechanger
10-13-2015 10:56 AM
