Noobs only
Old Apr 27, 2011 | 10:02 PM
Karanx7's Avatar
Unregistered Member
Noobs only
http://www.youtube.com/watch?v=L7_RsnD8hAU
Just found a useful video for those of use that have never changed our ATF. He used to work at an Acura dealership, and talks some nonsense about a flush tool at the end. Either way, hope it helps fellow novices.
Old Apr 27, 2011 | 11:50 PM
justjerkin's Avatar
Thanks!
Old Apr 28, 2011 | 08:47 AM
fsttyms1's Avatar
This is probably the best way to do it. (minus using dexron, and for the 00-03 guys you have to grab the line that the oiljet is hooked into)
http://www.youtube.com/watch?v=MsdPA...ature=youtu.be
Old Apr 28, 2011 | 06:08 PM
Karanx7's Avatar
Unregistered Member
Ok, I see. So you pull the oil jet kit out, and you feed that line into the trash can (or whatever).
Then you fill the ATF into the hole that the oil jet kit was originally inserted into? Also, will it fill in just as fast as it drains out?
Old Apr 28, 2011 | 09:36 PM
TequiLa's Avatar
(ಠДಠ)
when i did mine, the drain plug wouldn't come off so had to lift it and use an 18" breaker bar
Old Apr 29, 2011 | 02:24 AM
Karanx7's Avatar
Unregistered Member
Well according to fatty's video method, you wouldn't even need to take off the drain plug. Just the fill bolt if you have an 00-03. Or the trans cooler lines if you have a 99.
Old Apr 29, 2011 | 06:50 AM
fsttyms1's Avatar
do you see a "A" after the "F" and before "S" in my name
And if you watch the vid, he does drain the trans first. Then fills it with 3 fresh. Not sure why and im not sure it would be needed if you are just pouring all the new stuff in But this method is getting all new fluid in the trans and isnt using pressure to force the old out.
oo7spy
Jun 19, 2023 12:48 AM
Rcelestino93
Sep 23, 2015 10:01 PM
kocyk123
Sep 22, 2015 11:12 PM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
HOWELLiNC
Sep 5, 2015 03:09 AM
