TL not starting - not a battery issue for sure
Tried to start my TL this evening, and it won't start. It was parked outside since Friday, and the temperature was below 20F.
The engine was cranking fine, but it won't start. What should I do?
Checked the gas, there is enough in tank.
Everything there is to know about your Honda/Acura main relay:
http://www.tegger.com/hondafaq/mainr....html#blueline
http://www.tegger.com/hondafaq/mainr...mainrelay.html
When your about start it up key on engine off take a look at the check engine light, does it light up for about 3 seconds? if it does not you have an issue with the ecu or main relay. Its good to look at the easiest stuff first so you burn out your starter trying. Keep us updated
The main relay isnt a problem spot on the TL. The issue of the car cranking but not starting is usually due to the immobilizer.
Main relay has been an ongoing problem in all fuel injected Hondas since the late 80's until the design changed around 2005.
mada51589
05-03-2022 09:54 PM
cycdaniel
12-17-2019 11:58 AM
