Throttle Question
Old Jan 30, 2002 | 12:45 PM
tl-kode16's Avatar
Talking Throttle Question
If I replaced my throttle w/a Type-S throttle, I was wondering if that would give me more torque as well as top-end hp. If anyone could reply w/their opinions, please do. Thanks.
Old Jan 30, 2002 | 01:10 PM
AcuraTL's Avatar
OG
Since the Type-S throttle body is larger than the regular TLs, it should give you some gain in the top end. You will, however, need to port match it to the intake manifold. Also, you might want to do the I/H/E first before doing the throttle body.
Old Jan 30, 2002 | 05:46 PM
SoundSpeed's Avatar
I wonder if you could just have the stock TB bored?
Old Jan 30, 2002 | 06:08 PM
AcuraTL's Avatar
OG
You can get your throttle body bored out, but you will need to find a machine shop to make a custom throttle plate to fit into the new bored out throttle body. Plus, you still would need to port match the intake manifold.
Old Jan 30, 2002 | 07:19 PM
kman156's Avatar
Cool after mkt throttle body!
jc whitney sells a bbk edelbrock high perf throttle body for acuras (all) 92-2000, i believe it's 62mm. since the "res" won't be available for 99's this could be a good alternative . $300.00 5-8 hp gains? i'm trying it out, let ya know! kman
Old Feb 1, 2002 | 11:38 AM
tl-kode16's Avatar
Smile
An aftermarket throttle is even better. Kman, got a webpage for that compnay that makes the throttle bodies?
Old Feb 1, 2002 | 12:25 PM
AcuraTL's Avatar
OG
I believe they only make throttle bodies for B-series engine only, meaning for Civic/Integra/Prelude.
Old Feb 1, 2002 | 04:31 PM
kman156's Avatar
Cool just got it!
jcwhitney.com sells the bbk edelbrock 62mm high performance throttle body for all honda /acura 92-2000 accord , cl , tl , nsx. claims 8-12 hp gains . bolt on app, also go to www.bbkperformance.com. i'm thinking with the cai and throttle body a high perf fuel pump may be in order? let ya know...kman
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
navtool.com
Sep 25, 2015 05:15 PM
