Sway installation problem
Old Jan 15, 2004 | 05:15 PM
nick79's Avatar
the front saw i removed but i had a problem with the LEFT END POINT. the hex thread stripped so i had to cut the part off. how do i install the nut on the bottom back? the peice has two end points one for the sway and one on the bottom. the bottom nut seems impossible to tight. i am getting a new part but i dont know how would i tighten this nut.
Old Jan 15, 2004 | 05:20 PM
nick79's Avatar
this is the pic of the endlink. i had to use a saw to cut the middle off because the hex part inside the screw had stripped.
i dont know how i will install this back because the bottom nut is in a tight area where the wrench wont fit.
also any one know the exact name or part number of this part so i can order it thru Acura.
cycdaniel
Dec 17, 2019 10:58 AM
marcelft
Jul 10, 2018 06:17 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
NSolace
Sep 3, 2015 08:02 PM
