Swapped for odyssey tranny and now having some problems
Hello everyone,
I swapped out my junk transmission for a 2005 odyssey transmission. I'm having a couple issues as of right now and I was hoping that you guys might be able to help me out. My check engine light is on and it's P0141, O2 sensor, any ideas on why that would come on after the swap? Also, I'm having a shifting problem, it's not all the time, the car runs fine for a little while and then I lose fifth gear and the TCS light comes on at the same time and the D% light begins flashing? Any ideas
could of been damaged during install check and see if your o2 is damaged if not it could of finally went bad or something it is a platic sensor that reads oxgen levels I would try fixing it thecould of been damaged during install check and see if your o2 is damaged if not it could of finally went bad or something it is a platic sensor that reads oxgen levels I would try fixing it thecould of been damaged during install check and see if your o2 is damaged if not it could of finally went bad or something it is a platic sensor that reads oxgen levels I would try fixing it thecould of been damaged during install check and see if your o2 is damaged if not it could of finally went bad or something it is a platic sensor that reads oxgen levels I would try fixing it the reset and go see if it does not come back test drivingn reset and go see if it does not come back test drivingn reset and go see if it does not come back test drivingn reset and go see if it does not come back test driving
I think he meant the wire may have been damaged during trans swap
dont try to fix bad wire- resistance change will trick sensor
new front O2 is not many $, DENSO is the stock brand and available everywhere
codes are clues not diagnosis in themself..false codes appear too,,have to know where to look and put together symptoms and codes for final answer
does it run the same as always, or gas mileage dropped suddenly= O2
Ok, here's the other code that I just read off the computer P0715 input shaft sensor malfunction. I'm guesting that's giving me the problems with the shifting. The parts store didn't have anything like that in their system, anyone have a part #for me to cross reference.
Transmission was tested and ran fine, new fluid and cleaned all solenoids, new filter and installed an additional external oil cooler. Just a small one to help out a little bit.
OR....... you bought a bum trans......
Thanks for all the help guys, I just got done working on it and on of the connectors to the speed sensors the connection was bad because one of the pins broke, sodered a new one on and it shifts great so far. I'm still getting a check engine light so I'm gonna go get that read in a little while. hopefully it's just the O2 sensor malfunction.
Make sure no harnesses weren't caught between the engine and trans when they were married. Common problem I see come in with engine/trans replacements performed prior to visit. Also, check all fuses and ensure none were blown by harnesses/connectors grounding out to chassis, frame, etc...
dirtyspitshine
Jan 3, 2023 08:23 PM
HeloDown
Sep 8, 2015 06:51 PM
