Bosch Oil filter fitment problem (3312)
Old Sep 19, 2012 | 07:15 PM
Gabru678's Avatar
Question Bosch Oil filter fitment problem (3312)
Hey so I bought a Bosch Oil Filter 3312 and I couldn't get it to fit right on my car. It would go halfway up the screw on thing and then get really tight and not go any further. Has anyone else had a problem like this?
P.S. I previously used a Fram oil filter but after hearing bad things about them I wanted to go to a bit better one.
Old Sep 19, 2012 | 07:19 PM
MilwaukeeDave's Avatar
You need a 3322 according to Autozone.
Old Sep 19, 2012 | 07:29 PM
Skirmich's Avatar
Yup wrong Part No...! Thinks... OR Perhaps you got a Bad Piece?? Try to Return it for Another one and Try Again...
For 1 Dollar less you can get a K&N Entry-Level: http://www.autozone.com/autozone/par...65775_331639_0_
In Autozone.com I get part 3312 Like OP were did you get that Number "Mildave"?
Part 3312 seems right: http://www.autozone.com/autozone/par...artNumber=true
Part 3322 is a Slim Profile Filter doesnt seem to be right...
http://www.autozone.com/autozone/par...ier=190562_0_0_
Old Sep 19, 2012 | 07:38 PM
http://www.autozone.com/autozone/par...er=190562_0_0_ this is where. Order a K&N filter off amazon. I got one for 9.95 regular price was listed as 15. Comes w a 1" nut on end for easy removal = no stabbing it to loosen overtight filter.
Old Sep 19, 2012 | 07:41 PM
Skirmich's Avatar
That link says it doesnt fit my TL-S..
You got the HP-1004 then? White K&N Can? Thats the one I use ALWAYS....
And I always tighten up my Filter by Hand.. In 5 Years not a Single Issue with it.
Old Sep 19, 2012 | 07:51 PM
OP has TL-P not S if I'm not mistaken. Yup HP-1004. I always hand tighten too but when I got tires put on my odyssey they gave me a free oil change. They cranked the piss outta the filter. Had to stab it to grip it well enough to turn loose. Got both vehicles now w K&N filter and royal purple for oil.
Old Sep 19, 2012 | 08:00 PM
Skirmich's Avatar
TL-S and TL-P uses the same Oil Filter No worries.
Still I Changed to TL-P and says it doesnt fit XD Still gives me 3312 as the One that Fits for the TL-P.
Old Sep 19, 2012 | 08:13 PM
jra8858's Avatar
Whats wrong with fram? I use fram high mileage filters, should I switch to a different brand?
Old Sep 19, 2012 | 09:24 PM
Skirmich's Avatar
FRAMs are pretty bad and they can Colapse in Exteme Cases which is Unacceptable. Switch to BOSCH or K&N Entry Level which are Around the Same Price.
Old Sep 19, 2012 | 10:33 PM
jra8858's Avatar
Thanks for the advice. I just changed my oil about 500 miles ago. Is it cool to change only the filter between oil change intervals. If so should I add any oil after filter change. I use 5qts opposed to 4.7.
Old Sep 19, 2012 | 11:16 PM
Skirmich's Avatar
Yes if you change the Filter some oil will be lost but is less than 1q so No worries if you have a spare one.
Old Sep 20, 2012 | 05:20 PM
Gabru678's Avatar
Hmmm Well even that link that mildave had and I got 3312 also. :/
Well I just got a job at a ford dealership a while ago and am able to use the lifts so I will be able to take it up on a lift and see exactly what the issue is.
Old Sep 25, 2012 | 04:02 PM
Gabru678's Avatar
Ok so I used the lift at the Dealership.
And It wouldn't fit either.
Everything looked fine, threads seemed ok and all.
even a buddy looked at it.
So I just thought hey maybe its a bad filter, got a new one was at home and tried that one to
It STILL didnt work.
OK. So maybe its a bosche issue.
Lets get a WIX (51334) filter.
Nope still only goes up halfway and then tightens and wont go any further!
wat is going on?
anyone know or could throw a suggestion?
Old Sep 25, 2012 | 07:00 PM
RC99TL's Avatar
Check the threads on the bung on the engine. Has the treaded tube backed out of the aluminum housing? It is rare but would explain your issue.
Old Sep 25, 2012 | 08:56 PM
fsttyms1's Avatar
Been using them for over a million miles worth of driving. Never an issue.
Old Sep 25, 2012 | 09:22 PM
Karanx7's Avatar
Unregistered Member
That doesn't mean it's a good filter. That just means that engines can get away with shitty filters. Just do a youtube search of oil filter cutaways. There are simple facts that show FRAM is the worst quality filter that you can buy.
Old Sep 26, 2012 | 08:00 AM
Severin's Avatar
I actually started using the FRAM Xtended Guard XG3593A instead of the K&N because it's a good $4-5 cheaper. If you look on Youtube you'll see that they are actually pretty decent in the cut-aways. Haven't noticed any visible difference in the used oil. The only thing I miss is being able to ratchet the filter off the car. Most of the negative FRAM reviews are the orange can bottom of the line filters whose elements would collapse under pressure. The XG filters have a metal screen sandwiched in between two layers of filter material - no chance of collapse there.
I used to think Hundai's were garbage too, but things change and we're a little slower to catch up.
Old Sep 26, 2012 | 08:53 AM
fsttyms1's Avatar
Never said that it made it a good filter, but just because its not the best doesnt mean its bad either. There are horror stories out there about everything. Take CAIs for instance and water. The issues are far overblown from a few. No one hears or talks about the non issues. If they were as bad as the internet (because we all know every thing on the internet is true right ) they wouldnt be sold. They must do their job because both of my motors on the TL are just fine with 15k+ intervals and a filter change every 7500 I will continue to run the xtragaurd on the new motor that is going to be higher strung too.
Old Sep 26, 2012 | 09:27 AM
Karanx7's Avatar
Unregistered Member
Don't know anything about the XG, so I can't comment on that. But I can certainly say the cheap regular orange filter is bad. I'm not saying that it's not the best, I'm saying that it is terrible.
That being said, I'm running the cheapest orange filter on my new CL-S6 engine. Because you're right, it works just fine. Despite being the worst quality oil filter made, it won't cause any problems.
Old Sep 26, 2012 | 10:27 AM
acutee's Avatar
Bosch 3312 is the correct model.
Old Sep 26, 2012 | 12:55 PM
Check the threads for any burrs or metal shavings. Once at the dealership I thought everything was going great. Simple oil change on a new focus, it's very first one. Start removing oil filter. It hung up a little so I cranked on it. Ended up actually removing the plug the filter screws onto because there was a huge gash on the threads. Had to force it to turn out of the filter then use a thread file to clean it up. That and the time I got the filter stuck between the starter and frame on a V6 ranger were by far my worst oil changes. Thing sparked like crazy and burned a hole into the filter! Whoops
Old Sep 26, 2012 | 07:51 PM
Skirmich's Avatar
I didnt take the word on the Internet just did a Simple Test...
1 FRAM Filter for all 15K worth of Mobil 1 EP, Same with K&N Filter; I Know OVERKILL.
FRAM was 2 times Dirtier at the Change in 15K.. K&N was Noticeable Cleaner (Not Like New but It wasnt Brownish Gold like FRAM). So it Didnt Collapsed On me but It didnt do a good Job on keeping the Oil Clean Either.
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
pizokk1
Sep 17, 2015 09:29 AM
ghuns
Sep 16, 2015 04:26 PM
HydrasunGQ
Sep 14, 2015 10:14 PM
datadr
Sep 12, 2015 09:12 PM
