Starter question.......
Old Jan 31, 2009 | 01:07 PM
TV II's TL's Avatar
Roll Tide!!!
Ok, I'm sitting in the drive thru @ Walgreens pharmacy waiting to fill a prescription. Trying to save a little gas, I cut the car off. 5 min later I turn the key and I hear a ticking sound. At first I thought it was the battery cable b/c it tends to come loose. I popped the hood and it was fine. Then I thought the alternator but then I thought about the starter. I tested the battery and its putting out 12v. Any insight?? And how much do starters run?
Old Jan 31, 2009 | 01:47 PM
AMGala's Avatar
Lamborghini Aventador FTW
What year is your car? There is a recall on the ignition switch for '99s
Old Jan 31, 2009 | 01:49 PM
TV II's TL's Avatar
Roll Tide!!!
Its a 2000......
Old Jan 31, 2009 | 04:33 PM
fsttyms1's Avatar
Possibly a starter. Call your local auto parts stores for prices, they will be cheaper than the dealer. They arent hard to change on the TL.
Old Jan 31, 2009 | 06:22 PM
Rajca's Avatar
wham bam thank you ma'am
its easy to change and a lot of room to work with. try hitting the solenoid with a bat, pole, hammer,.. and see if it turns over. if u get it started its most likely it starter but never hurts to get it tested to make sure.
Old Feb 1, 2009 | 10:19 PM
TV II's TL's Avatar
Roll Tide!!!
It was the battery. Problem solved. The voltage meter was reading 12v, but it was still no good.....
Thanks for the input.
Old Feb 2, 2009 | 09:07 AM
totaledTL's Avatar
12v is too low.
Mike Pilipenko
Mar 26, 2024 09:21 PM
Jul 16, 2017 07:33 AM
agupta3224
Sep 22, 2015 08:08 PM
lovic87
Sep 15, 2015 06:07 PM
