spring install question
Old Apr 17, 2003 | 06:58 PM
badazzTL's Avatar
Peach Tea
when installing springs, do you have to take the axle out of the tranny or is there a way around it? when i got my GC coils installed, they took out the axle but my friend who is gonna help me install H&Rs says there is no need to take the axle out.. thanx for n e help.
Old Apr 18, 2003 | 08:18 AM
RandyY's Avatar
8th Gear
No need to remove the axle. But it was a little tricky to get the spring/shock assembly out. I had to turn the steering wheel 1/2 a turn from straight, get the assembly part way out, return steering to straight ahead, then get the assembly the rest of the way out. Reverse procedure to get assembly back in.
Old Apr 18, 2003 | 12:57 PM
badazzTL's Avatar
Peach Tea
cool thanx
Old Apr 18, 2003 | 03:03 PM
badazzTL's Avatar
Peach Tea
when i had my coils installed, i drove away and the axle popped out and i couldnt go n e where. i was so scared but it got fixed
Old Apr 19, 2003 | 01:32 AM
Seotaji's Avatar
my axle shaft popped out when i was installing the last spring.
took FOREVER to pop back in, and to top that the wheel bearing went bad too. jeebus.
Old Apr 19, 2003 | 09:20 AM
@cUr@-TL's Avatar
'99 Acura 3.2TL
hey corey u getting close to 2000 posts
@cUr@-TL
Old Apr 19, 2003 | 10:20 AM
badazzTL's Avatar
Peach Tea
so in order for it to pop out, you took the axle out right? if it did without taking the axle out, im afraid to do it..
badazzTL's Avatar
Peach Tea
@cUr@-TL
yea! i wanna try to get 2K posts before tomorrow
Old Apr 19, 2003 | 01:40 PM
Seotaji's Avatar
actually, the interior cv joint popped out by mistake.
it seems as though it were defective and had too much play.
you don't have to remove the axle shaft to install springs.
just turn the wheel to get better clearance and you should be fine.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
SinCityTLX
63
Mar 23, 2016 02:13 PM
Skirmich
Sep 15, 2015 06:41 PM
