Speedometer went crazy!
Old Oct 16, 2001 | 12:18 PM
Black TL's Avatar
I started my car this morning and when I put it in drive, my speedometer went to 100, stayed there for about two seconds and went down slowly to 0! WTF? I was like what the hell is happening. Has this ever happened to anyone? What could this be?
Rosh
Old Oct 16, 2001 | 12:47 PM
That happened to my 94 Vigor one time. The dash guages, particularly the speedo would shoot up and down randomly.
That was an early sign of failure of the ignition module which routes power to the guages. Luckily it only cost $60 to fix. Apparently this is a common problem with honda's/acuras.
Old Oct 16, 2001 | 12:58 PM
VTEC's Avatar
Talking
It happen to me but not my TL. My old 92 325i, i was stopping to a red light , i saw my speedometer go up to 130 mph, i was WTF
but it never happen again, only once.
Old Oct 16, 2001 | 01:07 PM
evolaerok's Avatar
This use to happen to my 323ci, but when I took it the dealer it acted as if it hasn't happened, but when I go on with my life and start again it does the same. Take it to the dealer, it might be the start of something.
Old Oct 16, 2001 | 02:06 PM
jkc2121's Avatar
the only time that happens to me is when i am riding on bald tires in the rain and i floor it
Old Oct 16, 2001 | 02:12 PM
daverman's Avatar
The speedo monitors the VSS (vehicle speed sensor) signal from the tranny. The VSS sends a constant number of pulses per tire revolution. It appears that you have an intermittent connector problem from your VSS which is causing spurious pulses to be detected, "spoofing" your speedo pulse counter into thinking that you're driving really really fast!
Old Oct 16, 2001 | 02:16 PM
It would appear that his tachyon pulse emitter relays are malfunctioning, possibly as a result of a breach of a plasma ECM conduit ....
Old Oct 16, 2001 | 02:47 PM
gohawks63's Avatar
It happened to a '95 Pathfinder we used to own. Turns out the gauge was bad and they needed to replace the entire cluster.
It would worke fine, then shoot to 100, down to 60, up to 80, then all of a sudden it would work fine for a while, then start all over again.
Old Oct 16, 2001 | 03:07 PM
songoku's Avatar
BlingBling INSPIRE 32V
Whatever the reason is...if something happened that isn't normal..I would take it to the dealer.... Warranty....
Old Oct 16, 2001 | 03:49 PM
daverman's Avatar
The solution is to remodulate the emitter arrays so as not to interfere with the graviton generators in the inertial dampers. That oughta fix it.
Old Oct 16, 2001 | 05:59 PM
zaptces's Avatar
yea its the sensor... i got a 92 Legend and that happends to me all the time sometimes the spedometer doesnt evan work and when you check wat gear your in (like D4) the light flashes non stop........ they told me $200 to fix it and I was like naa thats ok
Old Oct 16, 2001 | 06:14 PM
Nate's Avatar
Old Oct 16, 2001 | 07:54 PM
kensteele's Avatar
I guess too many of the non-trekkies aren't picking up on the lingo....
....in any case, I think it's early sign of failure and I would probably get it replaced (under warranty if possible) prior to total failure. I once had a speedo break on me and even to fix it, they wanted to write it off as "odometer mileage unverified" which basically meant the next buyer is not guaranteed that the mileage is correct (read: you are screwed). Luckily it broke at 150,000 miles and I sold at nearly 200,000; I think.
Old Oct 16, 2001 | 08:31 PM
speed's Avatar
eyedrj and daverman, you guys crack me up!
Old Oct 17, 2001 | 02:37 PM
patrick's Avatar
Yeah, better fix this real soon. You never know if the failsafe for the emitter arrays might cause a cascade effect and inadvertently signal the main computer that a core breach is in progress... You'll get no where fast! Just take the TL back to starbase 457 for some refit.:p
Old Oct 18, 2001 | 07:59 AM
jkc2121's Avatar
might want to get the flex capacitor checked out while you have it at the dealer. that could be the culprit also.
Old Oct 18, 2001 | 01:21 PM
Black TL's Avatar
Guys, it turned out that my myopletometrix was discombobulated due to the overnendent shomitent I did. They also checked my flex capacitor and it turned out that it was broken at the anterior mortal part. Thats what I thought was wrong the whole time.
ROsh
Old Oct 18, 2001 | 01:46 PM
ROsh
whew...Glad to hear it....as long as the hyper drive chamber wasn't destablizing the dilethium crystals power source. Of course this could cause a temporal rip in the vulcan mind meld
transmission mounts resulting in premature ejaculation
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
Retep Nitciaj
1G RL (1996-2004)
Oct 6, 2015 01:38 PM
Retep Nitciaj
1G RL (1996-2004)
Oct 6, 2015 01:36 PM
merc009
Sep 29, 2015 03:06 PM
MilanoRedDashR
Sep 24, 2015 11:04 PM
