Some problems, or not
Old Aug 20, 2011 | 04:04 PM
Karanx7's Avatar
Unregistered Member
I went to the dealership to get some parts. While I was there I got a free oil change + 30 point inspection. Ignoring the problems "due to mileage" which I have already taken care of myself, they found these problems:
+Replace rack and pinion assembly because:
-Found PS fluid contaminated (BS because I flushed it myself a few thousand miles ago)
-Found PS fluid low (Doesn't look low to me)
^Seems kind of overkill to replace everything
+Perform brake system fluid exchange because:
-Found brake fluid dirty/contaminated
^Probably true. I've never flushed it in 175k
+Replace left AND right inner tie-rods because:
-Found both worn out
^Should I be concerned? I'm clueless when it comes to suspension.
What do you guys recommend I do or ignore? Mostly, I'm worried if I should change the tie rods. My wheels get out of alignment pretty quickly, but I never really cared because of Firstone's lifetime alignment.
Old Aug 20, 2011 | 04:55 PM
Josh.'s Avatar
First things first, Tie Rods. Then brakes. If you did the PS and everything checked out ok, I wouldn't worry about it.
Old Aug 20, 2011 | 05:59 PM
01tl4tl's Avatar
diy the brake fluid= thats critical for stopping on the way to firestone
every year or 2 it should be flushed- simple diy, 2 qts DOT4 fluid and a buddy
PS fluid- near the upper mark is correct level,,watch while running
take to firestone and ask for front end inspection, since they do all your aligns-
they should normally ck the tie-rods anyway..especially if told it doesnt stay.
those are the part that is adjusted to change alignment!--
CRITICAL to safety and keeping it in align~
any `findings` that were total bs and not `reality` based- tell the service manager!
they are responsible for what the employee tries to sell you
Prevention is good- outright lies are not
Old Aug 20, 2011 | 06:02 PM
01tl4tl's Avatar
the steering rack- ck its end boots for leakage from inside
that would mean old fluid ruined the seals and replacement of entire unit is needed
Old Aug 21, 2011 | 10:04 AM
fsttyms1's Avatar
Tie rods break you crash. Fix worn tierods.
Old Aug 21, 2011 | 10:47 AM
01tl4tl's Avatar
ok its a tie--do you crash in the street from broken tie rods
or crash into a tree from no brakes?!
its your choice!
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
