So i checked my check engine light!!
I checked it by putting a paper. And I get 9 fairly long flashes. can someone tell me what code it gives and what should i do.
Thx
Thx
um what?
lol, I misexpressed myself :p
I put a paper clip in the OBD connector, so that the check engine light would flash and it flashed 9 times. I wanna know what code it gives and whats its description.
thx
thx
'99 Acura 3.2TL
P1456 (90) Evaporative emission (EVAP) system control leakage (fuel tank)
P1457 (90) Evaporative emission (EVAP canister system) system control leakage (fuel tank)
prolly ur gaz cap not closed properly!
i didnt think that was possible on our cars (obd2)
A 1457 is an evap leak on the canister side.
The only thing that seperates these two systems is the two-way valve.
The two-way valve can set both codes though.
Most common cause I think is overfilling the fuel tank and saturating the two-way valve, bypass solenoid and maybe the charcoal canister in an extreme case.
HeloDown
09-08-2015 06:51 PM
