Snow Cables
Old Jan 18, 2010 | 11:02 AM
LArockey85's Avatar
Snow Cables
I have a 2002 TL type S stock. i was going to drive up to mammoth this Thursday, i bought cables last season but did need to put them on. went to practice this weekend, looked in the owner book and it said not to put chains on a Type –S. Dose anyone have any experience?
Old Jan 18, 2010 | 11:04 AM
TLin401's Avatar
'13 Hyundai Sonata
It is all about your tires and how good of a driver you are.
Old Jan 18, 2010 | 11:07 AM
LArockey85's Avatar
What about my tires? I thought the problem was clearance
Old Jan 18, 2010 | 11:14 AM
TLin401's Avatar
'13 Hyundai Sonata
It is the tread pattern, tread life that is left, and the quality of the tire.
What kind of tires do you have?
Does it snow a lot where you live?
Have you ever thought about snow tires?
Do you have tread left on the tires?
Do you put weight in the trunk?
Old Jan 18, 2010 | 11:19 AM
Rajca's Avatar
wham bam thank you ma'am
i think u cant put chains on type s bc of clearance, damage to the rim. just get snow tires
Old Jan 18, 2010 | 11:21 AM
LArockey85's Avatar
I live in Los Angeles so getting snow tires are what im trying to do. They are mostly new tires on the car, I just replaced two of them in the last 3-4 moths and a third tire 5-6 months ago, so I do have good life in the tires. They will be weight in the car, two people, plus skis and gear. im going to need to double check the tires, i can remember off hand, but im sure i didnt get snow tires since i do live in LA.
Old Jan 18, 2010 | 11:27 AM
LArockey85's Avatar
If I cant put cables on I guess I cant take the TL bc im not going to get snow tires
Old Jan 18, 2010 | 11:32 AM
mastini's Avatar
O_o, you should change tires in pairs..., but i heard that different protectors helps car to handle road better
Old Jan 18, 2010 | 12:21 PM
LArockey85's Avatar
So i guess no chains/cables on my TL, guess im taking my gf civic.
Old Jan 18, 2010 | 12:25 PM
01tl4tl's Avatar
OK- lets back up and read the owner manual again- based on my 01s book:
it says use only type S Cable chains (and not regular chains)
Not Type S model TL cannot use them!! just use the correct chains, type S chain
Type S chain is the low profile cables, not the old school type with big links
Its a clearence issue on the inner side of the tire to steering and suspension parts
read book again- practice putting chains on at home, some find it faster to remove the wheel and install its chains then remount on car
Beats laying in the snow!
Old Jan 18, 2010 | 12:28 PM
01tl4tl's Avatar
Ca has chain requirements in the mountains all the time and the only exception is 4wd with studded tires
The TL does fine on cables- max speed 35mph and drive gently
Old Jan 18, 2010 | 12:58 PM
TheMightyQuinn's Avatar
Registered Nonmember
From my 2002 book:
Type S
Do not install any types of chains
or cable-type traction devices on
your vehicle.
That being said, I have used cables on my 02 TL-S with no problem for a couple a weeks during a huge snowstorm. Clearance was fine (not dropped.)
Old Jan 18, 2010 | 01:35 PM
LArockey85's Avatar
yeah i have a 02 type s and my owners manual said not to install any type of chains or cables, i bought cables last lease and did use them, red the manual this past weekend then i was going to practice putting them on and the manual said not to do it.
Do you know why, is it a clearance issue, is the mannual just being overly safe? Has anyone done it? should i just take buy cables for my gf civic and take her car to Mammoth.
Old Jan 18, 2010 | 01:37 PM
LArockey85's Avatar
its a stock 02 TL Type -S no drop no kit, factory,"That being said, I have used cables on my 02 TL-S with no problem for a couple a weeks during a huge snowstorm. Clearance was fine (not dropped.)"
So you have done it and its fine?
I have the S type cables
Old Jan 18, 2010 | 01:43 PM
LArockey85's Avatar
there is apparently a difference between the 01 and the 02 TL type -s in regards to this issue bc my manual said not to but if you have and its was fine it save me another $60 on chains for my gf civic
Old Jan 18, 2010 | 02:28 PM
Rajca's Avatar
type s is only 02-03 no 01
Old Jan 18, 2010 | 02:43 PM
LArockey85's Avatar
Then he is mistaken with his 01s.
The Manual for my 02TL-S
say:
Type S
your vehicle.
Has anyone done it any way?
Did it cause damage?
I do have the type S Cable chains
Old Jan 18, 2010 | 02:48 PM
LArockey85's Avatar
Originally Posted by TheMightyQuinn
From my 2002 book:
Can anyone else attest to this?
Has anyone else used them with no problem?
i called two dealerships and one said it was find and another i called just quoted the manual and but couldnt give me a reason why i cant put them on.
Old Jan 18, 2010 | 03:19 PM
01tl4tl's Avatar
sorry- my 01 is type P and the manual does allow for typs S cables only- and it also has 16 inch rims so that may be the differance
Test fit them at home and see if anything will hit
Old Jan 18, 2010 | 03:46 PM
LArockey85's Avatar
yeah that's a good idea, i will just try them tonight, so if its not going to work your saying ill be able to notice it hitting something on the other side of the wheel
Old Jan 18, 2010 | 07:31 PM
Yes, I have done it on my stock type-s without problem.
Old Jan 18, 2010 | 09:48 PM
TouringLow's Avatar
no offense, but dont listen to this guy. he's from the east coast and they have different living and driving conditions.
get snow chains and read the label of which size fits your overall diameter. its easy
last forum i was at had a huge argument between west coasters and east coast people because over there, conditios get so harsh you need snow tires and a lot of them never even heard of a snow chain..
but yeaa, use your common sense bro.
Old Jan 18, 2010 | 09:50 PM
TouringLow's Avatar
btw, just make sure its really tight. i know when theres a storm, people hate having to go out and put them on in the freezing weather so they do it quick and loosely.
Old Jan 19, 2010 | 10:45 AM
LArockey85's Avatar
was yours an 02, i dont understand why the manual says not to.
Old Jan 19, 2010 | 10:47 AM
LArockey85's Avatar
Yeah i was talking to ppl from Michigan and they didnt know what chains or cables are either,
Old Jan 19, 2010 | 11:41 AM
01tl4tl's Avatar
thats why they provide so much tv footage of worlds worst.... crash slide on ice bang! drivers--
Once the tires are on with the chains- place a piece of cardboard under the tires and turn the wheels- well have someone turn the wheels while you lay on the ground and watch
If its going to hit it will be a side part of the chain or fenderlip
bungee cords offer extra tightening when used on the outer side- in a triangle pattern, look at any semi truck for illustration
Old Jan 19, 2010 | 11:52 AM
LArockey85's Avatar
Thanks that is good advice. i will try it tonight when i get home. i was unsure if one could only tell if it was hitting something when you are driving or if ur advice will suffice. but there i`ll check tonight.
Old Jan 19, 2010 | 04:15 PM
LArockey85's Avatar
so i found out the the 02 TL type s comes stock on 17`s when the standard 02 TL comes stock on 16`s and its that difference that which is why they put that "Type S
your vehicle." in the owners manual of the 2002 TL Type S
cycdaniel
Dec 17, 2019 10:58 AM
neuronbob
23
Jul 16, 2019 10:48 AM
johnalfa
Oct 31, 2015 12:55 PM
ValdezQ26
Oct 1, 2015 04:48 PM
jaimbot
Sep 17, 2015 09:25 AM
