signal light (yellow lights) help!
Old 11-12-2009 | 01:16 PM
mrboombakid's Avatar
i don't know if any of you have done this before, but what i'm trying to do is unplugging the yellow lights in each side-end to enhance the look in the front. The question is if i removed the yellow light plugs, would my signal lights still be working?
Old 11-12-2009 | 01:40 PM
jjashaa's Avatar
Avant Garde Wheels
sure
Old 11-12-2009 | 02:25 PM
hANDYcaptd's Avatar
It's the Halladay season!
I have no idea what you're trying to do...
Old 11-12-2009 | 02:28 PM
ScottayHiFive's Avatar
Are you trying to disable the parking/corner lights so that they only come on when you turn on the turnsignal???
Cause if you remove the plug the light is completely out.
Old 11-12-2009 | 04:08 PM
yeah i wanna disable the yellow lights that are used also as signals
I want the yellow to come on only when i signal, otherwise i want it to be off so my hids will show only
Old 11-12-2009 | 04:33 PM
Just use electric tape to cover up one the prongs on the bottem of the bulbs. Do that on both sides and your all good.
Old 11-12-2009 | 04:36 PM
jjashaa's Avatar
Avant Garde Wheels
i did this. looks 100x better with 6k low beams an 3k/2500k fogs.
and take off the lower 168/194 bulb size.
Old 11-12-2009 | 04:40 PM
ANC297's Avatar
Bonki' Ehrite!
While we are on the topic of turn signals, how do you replace the rears? Do you have to open the entire tail light assembly or do they just pop out?
Sorry OP, but I figure better to use an existing thread than to make a new one.
Old 11-12-2009 | 04:42 PM
jjashaa's Avatar
Avant Garde Wheels
^ unscrew those things
pull away the lining.. and you'll just see the sockets.. twist and pull out.
its just like the headlights.
Old 11-12-2009 | 05:10 PM
ANC297's Avatar
Bonki' Ehrite!
Thanks!
Old 11-14-2009 | 03:33 PM
so one wire runs the solid yellow light and one wire runs the signal light?
Old 11-15-2009 | 02:59 AM
I think so... But your better off not cutting the wire. Just take out the bulb and put electric tape on one of the prongs thats located on the bottom of the bulb and your parking amber lights will be off and will only turn on when you use the signals.
Old 11-15-2009 | 04:10 AM
TouringLow's Avatar
its gonna be like those bombs in the movie...
there are three wires, black, green and orange..u cut one, not sure which one.
but atleast you dont blow up if its wrong =p
Old 11-15-2009 | 10:18 AM
TLin401's Avatar
'13 Hyundai Sonata
Yes.
This is a cool mod for the 2G.
mada51589
05-03-2022 08:54 PM
space_boy
ILX
51
08-15-2017 12:06 PM
sockr1
10-01-2015 01:31 AM
Greengecko
09-16-2015 08:19 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: signal light (yellow lights) help!
