SHOCK sensor revisited
The 2nd can be hooked up to the horn for "warn" chirp. The SS44C dual sensor has a current sensing loop that can be cut and connected to the hot wire of the ignition (ei, wire positive wire that is on when the key is in). This will disable the current sensing, thus disabling the shock sensor so when you start the car, your horn will not chirp...
