shock sensor for OEM alarm?
Old Jul 22, 2004 | 11:08 AM
tim817's Avatar
For those that afraid losing your headlight but don't want the expense of an expensive aftermarket car alarm. This might be your solution bottom of page)
http://www.c-c-c.net/CustomCarCreati...Page/index.htm
I read somewhere in here that someone had this before but not sure how it works. Sound like a good deal since our car has factory alarm already/ keyless entry/ key-start feature
Old Jul 22, 2004 | 11:13 AM
tim817's Avatar
Old Jul 22, 2004 | 11:14 AM
tim817's Avatar
damn, still not working.Ok,click on the acuta tl button, click on security and scroll down on the next page.
Old Jul 22, 2004 | 11:29 AM
@cUr@-TL's Avatar
'99 Acura 3.2TL
i have an adjustable shock sensor and it works like a charm. really easy to hook up too!
@cUr@-TL
Old Jul 22, 2004 | 11:51 AM
Davidlamny's Avatar
Where did you place those sensors?
Old Jul 22, 2004 | 03:10 PM
hzm82's Avatar
I placed the shock sensor within the fuse box. The main problem I have is that after you set the alarm, and leave it for 30sec. Then come back and press the lock button again, the alarm would go off. I was thinking that the relay sound kicking in trigger the shock sensor so I lowered the shock setting and moved it away from the fuse box and it still did that.
Other people have problem with the sensor going off when they shut the trunk. I personally never had that problem. I personally didn't think this mod was that great. Just getting one shock sensor isn't enough. You need atleast two shock sensor on each side of the car.
If you search the net, you can find generic dual shock sensors for a cheaper price then www.c-c-c.net.
Old Jul 22, 2004 | 05:39 PM
I installed the DEI shock sensors per novawhitetls 's instructions, works great
Old Jul 23, 2004 | 10:45 AM
tim817's Avatar
Can you tell me where to get that shock sensor and the instructions?
Old Jul 23, 2004 | 10:48 AM
tim817's Avatar
I think I found it:
http://acura-tl.com/forums/showthread.php?t=22031
cycdaniel
Dec 17, 2019 10:58 AM
wb2ee
2G RDX Problems & Fixes
Sep 22, 2015 12:00 AM
Sep 17, 2015 09:01 PM
Billu99tl
Sep 13, 2015 11:30 AM
MyKids&Cars
Sep 1, 2015 12:53 PM
