Shiftgate 1><2?
Blown is Best
Also note that if you start out with the gate in 2, your car will be sluggish because it will be in 2nd gear (not 1st gear from a dead stop). From a dead stop, 1,3,4,5th gate will start you out in 1st gear.
only if you're racing cause you can hold 1st gear longer. I've noticed that when I shift from 2nd to 3rd through the gate the shift is quicker. With SS, when I shift up, there is slight delay before it shifts.
actually I find more the opposite, I find that when gate shifting, I have to shift somewhere around 6900-7k RPM or else I bounce off the rev limiter, thus losing a **** load of time. In SS mode, it pretty much shifts instantly, give or take like 0.2 seconds.
Originally posted by SeCsTaC
With gateshifting or SS do you have to let off the gas for a sec to shift? or do u just keep on it and shift.
later
Comptech Freak
don't put at 2nd to start, coz it starts at 2nd gear!!!
honda puts 2nd gear as the winter purpose~
SS is better if u know when to shift...around 6800rpm...
