Shift Knob
Old Apr 4, 2007 | 03:06 PM
Ninety9's Avatar
That's rubbish...
Shift Knob
So I'm thinkin about buying a B&M chrome polished shift knob for my 99 TL-P. How can the stock knob be removed? Is there a technique? I don't want to break it..lol. Any feedback would be welcomed.
Old Apr 4, 2007 | 03:14 PM
merkin110's Avatar
The technique is pretty simple....Just twist it off.
Old Apr 4, 2007 | 03:37 PM
Ninety9's Avatar
That's rubbish...
Is it a screw type pattern that just unscrews around the stick and the knob comes off? Or is it like glued or put on a different way in which its not intended to be removed?
Old Apr 4, 2007 | 04:05 PM
orgnlprankster7's Avatar
08 Civic SI
nope just unscrew it. its that simple, may take a little force at first.
Old Apr 4, 2007 | 04:21 PM
Malayalee King's Avatar
ഥഎണഡഏ Fellas Inc.
well on the 02/03s there is a metal collar/ring at the bottom that you will turn counterclockwise (asssuming you are sitting in seat) and then you can start turning the knob once that is removed. i'm not sure if you can remove them both at the same time, but i would do it to be safe (such a long time ago).
good luck
Old Apr 4, 2007 | 05:00 PM
gaping46and2's Avatar
SOLD: 03 SSM CLS Auto
I don't believe that's necessary. Righty tighty, lefty loosy it all you need to know.
Old Apr 4, 2007 | 05:02 PM
fsttyms1's Avatar
good luck
All you need to do is twist counter clockwise
Old Apr 4, 2007 | 05:15 PM
ഥഎണഡഏ Fellas Inc.
oh...maybe i was thinking about the knob i have now...haven't seen the stock one in a while, my bad! good to know
Old Apr 4, 2007 | 06:11 PM
6MTUA5's Avatar
No He Can't
yea, if it is your first time taking the stock knob off, it will take quite a bit of force to get it going. but once you break the seal, it is easy from there.
Old Apr 4, 2007 | 06:14 PM
fsttyms1's Avatar
the stock one is just held on by threads, nothing else clips it on
SidhuSaaB
May 30, 2020 12:40 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
Popee
Dec 20, 2015 12:08 AM
mellsonnj
Sep 24, 2015 04:42 PM
Hines57
Sep 24, 2015 01:58 PM
