self installation
Old Oct 24, 2002 | 06:20 PM
self installation
Does anybody have instructions on how to install an HKS exhaust? Since it's a bolt on exhaust it can't be that hard, but how do you take out the stock exhaust, because it looks likes it's welded on, or should I just take it to a shop to have it done?
Old Oct 24, 2002 | 06:42 PM
badazzTL's Avatar
Peach Tea
Re: self installation
its very easy, just use WD-40 to loosen the bolts and bolt it right on. HKS comes with gaskets so just use those. did you get ur exhaust yet?
Old Oct 24, 2002 | 07:14 PM
no not yet, just want to get some info before I go ahead and get it. Do the stock exhaust is only held on by a few bolts? Where are the bolts located? Do aftermarket exhausts hook up with the catalyic ?
Old Oct 24, 2002 | 07:46 PM
badazzTL's Avatar
Peach Tea
there are 2 bolts on the end of each muffler where they connect to the Y pipe. installation is very simple. no they will not hook up with ur cat cuz they are just axle-back mufflers. if you were to get cat-back it would replace the cat and resonators...
Old Oct 24, 2002 | 07:58 PM
sssick's Avatar
Dude just stick your head under there and youll see. Two bolts and two hangers. It took me 25 mins to do mine.
Old Oct 24, 2002 | 08:38 PM
O.....so i'm just paying for mufflers? For the longest time I thought it was the whole exhaust. hahahaha. Do i gain any HP?
Old Oct 24, 2002 | 09:09 PM
Ryan's Avatar
did any of you guys who did the install youself need some sort of Impact/Air wrench to remove the bolts???
Old Oct 25, 2002 | 05:31 PM
baggsTLS's Avatar
Mr. Self Destruct
Impact tools are not necessary. Just use some WD-40 to loosen those puppies up and then add elbow grease. You should get these off in no time.
and yes, you're paying for mufflers and may see 2-4 hp gains. nothing to get excited over.
badazzTL: one clarification, if you get CAT back exhaust, you're not necessarily replacing the cat. MOST (if not all) cat back systems START at the cat and go all the way back. you can however, get rid of your cat for a straight pipe.
Old Oct 25, 2002 | 05:49 PM
Since we're on the subject of HKS draggers.....anybody looking to sell a set?
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pistacio
Sep 26, 2015 09:45 AM
TxRzrBk
Sep 17, 2015 01:07 PM
